![]() | Home > Td5 > interior light |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
No, the lights are permanently live, but the ecu switches them to earth if the door is opened. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467
The interior lights are controlled by the 10AS alarm unit (ECU) which has inputs from all the door and bonnet pin switches to activate the alarm.
There are 2 or 3 different options for the way the interior lights work but it will need to be programmed with a suitable diagnostic tool, e.g.. Nanocom or similar. |
| yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230
Thanks guys
I didn't think I had an alarm? 2003 defender 90 pick up |
That is line with you interior lights problem then... Think you had an alarm, but it (the AS10 unit) has been disconnected.
I have the same problem with the lights, because the previous owner installed an after market alarm and immobilser unit in stead of the AS10... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Any idea why it would be disconected?
I don't even have an alarm fob?
There were some problems with immobiliser unit (spider), mostly bad solder connections on the pcb board, but that was with the earlier models (300 tdi), but I guess that would have been solved by 2003.
Edit: If you don't have a fob, then clearly the alarm/immobiliser unit has been disactivated! Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Easy enough to check and see, if you have one, the 10AS will be mounted on the bulkhead behind the speedo binnacle, either remove the binnacle (4 screws,) or the speaker below it and look up inside with a torch. The 10SAS is a green box about the size of a smartphone but a lot thicker with two multiway connectors on the underside.
Edited to add; what year vehicle is yours? |
2003 90 pick up. I should get an alarm /I mobilise
Yep, just took the clocks out and can see the green box with a land rover sticker on it.
Can it be connected and can I get a fob? Or was it disconected because it caused problems? |
I guess the latter...
Recommendations for a good alarm then guys????
Thanks for all the comments. |
I don't believe the 10AS is generally too unreliable and you could get a fob, problem then is you will still need a diagnostic device in order to pair the fob with the unit, (assuming it does actually work.) It could just be that the original fobs have been lost or broken and the immobilised disabled.
Incidentally the 10AS can also control the central locking if you have it, although being a truck cab I suspect not, in that case a couple of parts will be missing but they can be added later. |
Cheers Clive.
| All times are GMT |
