Home > Technical > Boomslang headlight loom problem
Mwd
I have a strange headlight problem. I fitted a boomslang loom 2 months ago and it has worked perfectly, until now... I now have one headlight functioning normally (near side) - dip and beam work correctly, and are good and bright, but on the other side both dip and beam filaments are dimly lit at the same time, irrespective of the position of the dip switch. It looks like both filaments are getting a much lower voltage than they should be. I don't think this is a problem with the relays since I have once light working normally, and I've tried a new bulb but there was no difference, so it isn't the bulb. Before I take the whole loom apart to find the fault, does anyone have any experience of this sort of problem, and how to fix it?
Post #555559 12th Aug 2016 1:37pm
K9F
Boomslang looms are notorious for quality and problems related with them. Get a Landreiziger one instead would be my advice.
http://www.defender2.net/forum/topic41796....=boomslang
http://www.defender2.net/forum/topic41788....=boomslang If you go through life with your head in the sand....all people will see is an ar5e!!
Post #555568 12th Aug 2016 2:11pm
Almost certainly an earth fault (open circuit) on the side with the dim filaments.
Post #555585 12th Aug 2016 4:24pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
OT ... anyone have issues with the light switch, I know it was an issue on the 2.4s, what about the 2.2s?
Post #555673 12th Aug 2016 10:58pm
Happyoldgit
Same switch, same issues. Steve.
http://forums.lr4x4.com
Post #555676 12th Aug 2016 11:27pm
bm52
typical
Post #555849 13th Aug 2016 11:02pm
