Home > Puma (Tdci) > How much play is ok in front propshaft / transfer box?
ceefax
United Kingdom 2016 Defender 90 Puma 2.2 HT Keswick Green
Rolling Eyes
With only a couple of thousand miles on the clock my 90 is going back for warranty repair - the front output seal on the transfer box is leaking, so after every run there's a little puddle of gearbox oil on the driveway.
While I was under the vehicle looking for the source of the leak, I grabbed hold of the front propshaft, and was surprised at just how far I can turn it backwards and forwards (with the vehicle on the ground) - maybe 10-15 degrees of movement?
Turning it produces a loud "clonk" from within the transfer box, so it's not surprising smooth gearchanges are so difficult!
I would really appreciate some help on what is "normal" and "acceptable" before I take it in, I will be showing the service manager the issue, but am bracing myself for the "they all do that sir" reply!
Thanks!
Post #554223 7th Aug 2016 11:53am
ceefax
Hmmmm - 120 views and not a single reply.
I've taken to walking the streets asking Puma owners if I can twist their propshafts Wink
so far I've tried three others, and they all have a little play, but nothing like as bad as mine. It's going in next week so I will see what they say.
Post #555582 12th Aug 2016 3:53pm
miker
Mine is far far older, (like 17 years and 185000 miles!) but has similar amounts of play in it. I haven't gotten round to seeing if the play is in the diff or the transfer box yet.
Does it look like the UJ's are moving at all?
EDIT:
To expand with some thoughts, the general attitude seems to be "they all do that" and I've never found a hard figure for what is "ok". Up to and including ashcroft commenting on mine when fitting the new gearbox "rear diff has some slop in it, but it's a salisbury, so i wouldn't worry" They didn't mention the front as something to be concerned over!
Post #555586 12th Aug 2016 4:28pm
Happyoldgit
If the play is worse in yours than others of a similar age / mileage then it's worth pressing the matter with the dealer, if they get snotty find a decent dealer. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #555601 12th Aug 2016 5:52pm
Sounds simple but it's worth checking the difference between the rear prop and front.
They can vary, obviously make sure it's either on a lift or completely secured as you'd need it out of gear and handbrake off for the rear.
Mines got a bit of play, about 6 - 10 degrees I'd say at a guess - I'd say about normal in my case @ 52k
Post #555610 12th Aug 2016 7:00pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Give it a good greasing and see if it helps.
Post #555627 12th Aug 2016 7:57pm
ceefax
Propshafts UJ's are tight. no movement there at all.
Parked up, in gear, with the handbrake on, the slack / backlash is in both the front diff or axle and inside the transfer box.
The weird thing is that the "clonk" which stops me hand turning the propshaft any further is coming from the transfer box - suggesting there's even more slack in the front axle somewhere ? Shocked
Anyhow - will take it back in and see what they say.
And thanks for the feedback and advice!
Post #555930 14th Aug 2016 1:42pm
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Having only ever owned used Defenders, I'm used to backlash in the transmission and use the clutch carefully to try to avoid "clunk" and breaking anything. Always assumed wear and tear takes it's toll over the years. Interesting to hear of a relatively new model with backlash. Mine has 85000 miles on the clock. In gear, handbrake off, with wheels chocked, I measure 25mm rotation at the handbrake drum, before it "clunks". The play seems to be in the transfer box. Not got round to checking half shaft/drive plate play yet.
Post #556009 14th Aug 2016 7:34pm
nickhodgson
The 'play' you describe in the transfer box and front diff sound normal compared to all the defender I have and have previously had. Unfortunately with a Defender you do have to drive with more care when releasing the clutch to reduce clunk noises and associated wear from the drive train.
Yes compare it to another Defender can be helpful but also monitor any driveline whining/whurring when you are on the move. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #556597 17th Aug 2016 6:36am
Happyoldgit
As I've said in the past on here before, you could line up several factory fresh or virtually new Defenders and each would drive differently, some would be spot on without a hint of play whereas others would feel as slack as a slack thing can be. Steve.
Post #556626 17th Aug 2016 10:06am
jst
that amount of play sounds acceptable to me Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #556715 17th Aug 2016 5:09pm
