![]() | Home > Maintenance & Modifications > Fuel Leak... Have you seen this before? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I think it may be one of those things where the easiest way to solve it is to take the back axle out, drop the tank then reverse the process. But that seems like taking the long way around but far better than "popping" it out.
I wonder how they do it when installing bigger metal long range tanks? Bit of a pain really, makes me think it was easier when 90's had their tanks under the driver's seat. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1058 ![]() ![]() ![]() |
I thought I had a problem with this, but turned out that there's a thin breather pipe too (may have another name?) that had become detached. Bit of plastic cable tie and all fixed. My 2.2 Puma had the problem from new. After a bit of a panic, was luck to have another Defender drive by. No problem taking a look round his fuel cap for comparison. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20851 ![]() ![]() |
I need to replace this breather pipe on mine too.
![]() The pictures are helpful, and I too would go for the aftermarket pipe route. (It has a certain spec.) The LR pipe is not good at all. Also, possibly a stupid question and one I should know the answer to but what is the 'shepherds crook' looking breather under the opposite wheel arch for? I'm tending to think battery breather, but maybe I'm barking up the wrong tree. This one really needs replacing too. Any P/N's for this one too? ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
