Home > Technical > Puma 2.4: Nanocom vs Hawkeye vs IIDTool
Batbloke
I've seen lots of good posts (including the stickies on here) about these various devices but they are all a little dated now.
If you were buying today, what would you choose and why? Do they all now cover the ABS & Alarms? Can they all programme key fobs? Are there any 'gotchas' with one or other compared to the rest?
I've spent a lot of time searching the web (and asking questions of some of them directly) but would really value any personal, experienced-based assessments before I press the 'buy' button on one or other of the.
Thanks
Post #555563 12th Aug 2016 1:51pm
See lorryman100's thread, current and factual
Nanocom would be my choice Thumbs Up
Post #555565 12th Aug 2016 1:53pm
Lorryman100
IID BT tool is my choice of a stand alone tool mainly because they have the most helpful customer service and are the only company actively improving their tools functions based on user feedback. JMTW :thumbsup:
Post #555617 12th Aug 2016 7:13pm
Batbloke
IID BT it is then. Thank you Smile
Post #555721 13th Aug 2016 11:42am
agentmulder
Kuwait
My IID BT came with my BAS remap, maybe it doesnt have all features? Certainly doesn't have fob programming (which I needed!).
I'd also be interested to see if some kind of instantaneous mpg value could be distilled from all the live values... Solved the bowel problem, working on the consonants...
Post #555727 13th Aug 2016 12:50pm
Batbloke
Ive got two keys and two fobs so, with luck by the time I need that functionality, if it doesn't have it now, perhaps they will have added it by then!
Meanwhile, I'm just off to see if my fobs will float. What could possibly go wrong...
Post #555728 13th Aug 2016 12:53pm
agentmulder
Kuwait
If you're going to get an IIDTool, I thoroughly recommend going down the BAS RR2 remap route. Solved the bowel problem, working on the consonants...
Post #555732 13th Aug 2016 1:01pm
Batbloke
I have looked at that (and others) but as this is my first Defender (had series, RR and D1/D2 in the past), I'm going to see how I go for a while first.
I don't do heavy towing - it was bought for our work which sometimes involves the need to cross rough ground. Currently getting 33mpg on the first three tankfulls. I am a very sedate driver.....mostly...unless I'm on a bike.
Post #555736 13th Aug 2016 1:19pm
sat13
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
agentmulder
If you need key programming, let Gap know and they will hopefully let you have the latest update to include it.
Last time I spoke to them it lt was still in beta but they let me try it.
See post http://www.defender2.net/forum/topic38873-15.html way down on page two.
It worked very well and programmed my new key no problem. It needed tweaking slightly but they may have ironed out the bug by now. (see above post).
Hope it may help.
Regards.
Fletch.
Post #555803 13th Aug 2016 8:12pm
Batbloke
That's good intel for the future. Thank you Smile
Post #555909 14th Aug 2016 11:27am
Cupboard
The IIDTool does have fob programming. Definitely.
I have an IIDTool that I'm currently having some issues with, but I have to say their customer service is currently spot on. We haven't managed to fix the problems yet but they are being helpful and replying promptly to emails even sometimes at 11PM.
Post #555939 14th Aug 2016 2:54pm
agentmulder
Kuwait
From Peter as BAS:
Quote:
The BAS2 is engine only and so does not program new plips
Big Cry
Unless I'm mistaken it looks like the IIDTool that BAS use has a (purposely?) restricted functionality.
I'll get in touch with him and find out the relationship. Solved the bowel problem, working on the consonants...
Post #555994 14th Aug 2016 6:43pm
The BAS RR2 device is NOT an IID BT tool, it is a remote remap programming tool that happens to be built in a similar enclosure to the IID tool but has engine-only functionality. If you read the blurb on Pete's website he makes it very clear that this is the case.
Pete is also a distributor for the IID tool, and if you are in the market for one personally I recommend him as a supplier, since his aftersales service is second to none. I have no connection with Pete or BAS except as an extremely satisfied customer (my remap and my IID tool came from him), but I cannot recommend him too highly.
To reiterate the point though, be aware that the BAS RRC2 and the IID BT tools are completely different tools for different purposes, albeit similar, and you need to make sure you buy the right one.
Post #556071 14th Aug 2016 10:04pm
agentmulder
Kuwait
They share not only the enclosure but many functions and user interface.
I could be wrong but coming from electronics manufacturing I know that many devices like this are built as the same unit in terms of both PCB, parts and MCU/FPGA etc but then simply programmed differently and/or put in a different cosmetic enclosure. (quite a lot like engines and tuning actually)
Makes economic sense at certain scales of production.
But yeah, again I could be wrong... but I suspect to get full functionality BAS would just need to pay more for an extended licence or similar and the functions would turn up in the next download. BAS would then pass those costs on to the customers - if they're just after the remap then maybe the lower cost is a good thing...
Then again, maybe it is a completely different bundle of electronics for good reason, but I'd wonder why, considering the logic I outlined above.
And so the world turns Thumbs Up Solved the bowel problem, working on the consonants...
Post #556106 15th Aug 2016 2:59am
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
I'd never ever access my car's ECU with a mobile device, would you - honestly? Shocked
From my point of view: This sorts the IID tool out ( as long as I cannot service the ECU's software myself)
Julia
P.S. Feels also very uncomfy for me when the retailer accesses my car's ECU with his WiFi equiped laptop Neutral
Post #556160 15th Aug 2016 12:31pm
