Home > In Car Electronics > DRL/ engine running feed
Cheshire110
Going to get some DRLs for my 110 but ideally want to keep clear of those horrid little voltage sensing units which cost Ł7 off eBay... Is there a way to get an "engine is running" rather than an ignition feed somewhere?
Or are there good quality controllers available if you know where to look?
don't need anything fancy - just on with engine, off with sidelights Cheers, David
Post #554445 8th Aug 2016 12:58pm
Cheshire110
No-one have a better solution than a voltage sensing box? Cheers, David
Post #555060 10th Aug 2016 3:16pm
You could use the "engine running" signal from the IPAC for a professional approach, it is what it is for. Normally used for enabling the heated windscreen.
Post #555081 10th Aug 2016 5:14pm
Cheshire110
Sorry if it being thick but what's the IPAC? Cheers, David
Post #555094 10th Aug 2016 6:44pm
dgardel
Italy
The instrument cluster Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #555160 10th Aug 2016 10:22pm
Instrument panel.
Post #555161 10th Aug 2016 10:23pm
Cheshire110
Gotcha thanks guys, what exactly would I take the feed off? Cheers, David
Post #555162 10th Aug 2016 10:24pm
sat13
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Cheshire110
Don’t know if this will be of any help but if you are looking for a live engine running feed I took one off the main power relay under the driver’s seat.
It was easier to run the wires through the cubby box from this location to where my switch panel was mounted for controlling the DRLs.
See below its part of a post off the LR4X4 forum. The guy that helped me was PaulMc I could not have come up with this without his help.
Sat13 has informed me that he couldn't get the WN wire from C1040-14 to C1624 to trigger a standard automotive relay.
I've asked around, and it would seem that the WN wire only provides a 'signal voltage' to the electronic HFS Timer, it's incapable of providing sufficient current to drive the coil of a relay.
I was told that a better place to pickup an 'engine running' supply under the driver's seat, would be from the main power relay, which is switched by the engine ECU, which detects the engine running/charging, from connections to the alternator.
I've had a look at the PUMA Wiring Diagram and Electrical Library, and this would be the relays output on - C0063-87 (Brown/Orange wire)
Sat13 has confirmed to me that the Brown/Orange wire on C0063-87 is only live when the engine is running and that it's capable of triggering a standard automotive relay.
This worked well for me and it’s been in use now for a few years. With no problems operating my DRLs.
Regards to all
Fletch.
Post #555733 13th Aug 2016 1:04pm
Cheshire110
Thanks fletch,
That's really helpful! Cheers, David
Post #555742 13th Aug 2016 1:55pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
I have a hella DRL. its the smart type that can detect if your engine is running etc..
so I simply wired the DRL to the alternator in my puma 2.2 (permanent live) and ground. also connect the third wire to my side marker. thats it.
I do not need to get the wire via the rubber grommet and fishing behind the dash.
works a treat for 1 year now
Post #565714 21st Sep 2016 11:29pm
Cupboard
The "smart" boxes are pretty similar to a basic split charge relay.
Post #565997 23rd Sep 2016 9:28am
Cheshire110
I just don't like the voltage sensing ones, I'd rather use a proper relay and feed based system Cheers, David
Post #566004 23rd Sep 2016 10:17am
