![]() | Home > Maintenance & Modifications > Dynamat installation |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21039
Have a look on the CSK Land Rovers site, Chris used to have lots of good photos on there.
What you've said sounds right to me, I decided against fitting any under there myself though. I'm sure you are already savvy enough to ow to wear gloves when fitting, it has edges like razor blades when cutting abd fitting in. |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
This is the thread you need (prob what Steve refers):
http://www.defender2.net/forum/topic19837.html?highlight=dynamat |
Yep, some good ones there.
| TVM Member Since: 18 May 2016 Location: Dubai Posts: 35
Thanks Guys
Will go through the info cheers TVM |
| Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288
Had mine lined with a 19mm hood liner and it's certainly helped cut down on engine noise. I can't say how it was fitted though as I didn't do it.
Click image to enlarge |
Thanks Riverboy
That's the picture I was after. Do you have Dynamat extreme beneath the Hoodliner? Steve/Martin Thanks for the thread and quite useful info. The thread has the complete picture of installation. The only one missing is relating to hood!! I think I will do the Dynamat extreme first to the areas that can be fixed under the hood and then do a hoodliner Cheers TVM |
I'm not sure to be honest. The guys that did it did the whole car and did an amazing job so I suspect they did. In the main cabin they added new carpet trim to exposed areas and I wasn't expecting that. If you are doing it yourself then yes I would add as much as you can.
Argh... lol - "Hood" = bonnet
I thought "Hood" = roof lol |
No worries Martin
Managed to get the Dynamat extreme fixed to hood in patches followed by Hoodliner. Definitely lot better. Also managed to fix some to the foot well and the middle row floor. Cheers TVM |
| All times are GMT |
