Home > Puma (Tdci) > MY GAP IID Tool won't write stuff to my Defender.
Cupboard
I've been trying to change some settings in my Defender's computer and it keeps failing.
It will read settings quite happily but crashes every time I try and write something.
How do I know whether the problem is with the Defender or the tool? Do Defender computers get issues which mean I wouldn't be able to write to it?
Edit: ECU history, it's had Alive disable the EGR valve (and they didn't complain) and Remote Key program a new key to it (which worked fine). I've never been able to write anything with the GAP tool.
Post #554441 8th Aug 2016 12:47pm
Cold_n_Wet
Norway
What are you trying to write ? IOS or Android ?
Glen "Rafiki" 2007 110 STW - Rolling rebuild.
Post #554501 8th Aug 2016 4:29pm
Cupboard
Anything!
It's saying that the injector learning hasn't been done so I started off with that, but I can't even adjust things like the speed limiter or how the interior lights function.
Android.
If it's likely to be the tool at fault then I'll contact their support. If it's likely to be the Defender at fault then I've no idea what I'd do to fix it!
Post #554541 8th Aug 2016 7:37pm
Cold_n_Wet
Norway
Suggestions
If you have a IOS device try that, Check that the firmware is oppgraded to the lastest stabile and the App is up to date.
I havent flashed a Puma, but have done loads of D3 / RRS / evoque with it. "Rafiki" 2007 110 STW - Rolling rebuild.
Post #554544 8th Aug 2016 8:11pm
agentmulder
Kuwait
I cant recall exactly what it said and when but that message rings a bell.
In my case it was because the engine was cooling during the processes. It had to be above some value (that I forget, but it is in the manual if I recall) for the complete procedure.
Once I took it for a good blat and stored enough heat in the whole engine block and not just the area the heat sensor that the tool determines that it's ok to start because it's 'warm enough' it was good to go. Solved the bowel problem, working on the consonants...
Post #554617 8th Aug 2016 11:29pm
Martin
Site Admin
Drop GAP support an email, the service is very good.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #554740 9th Aug 2016 3:42pm
PatGAPInnov
Site Sponsor
Canada
Mail on it's way Thumbs Up http://www.gap-diagnostic.com/
Post #554769 9th Aug 2016 5:43pm
Cupboard
Credit where it's due, an email came before I'd sent one Thumbs Up
Post #554849 9th Aug 2016 10:01pm
agentmulder
Kuwait
What was the issue? Solved the bowel problem, working on the consonants...
Post #554874 9th Aug 2016 10:45pm
