![]() | Home > My Defender > Patsy, our 110 Hardtop |
Andrew*Debbie Member Since: 25 May 2016 Location: Anglesey Posts: 95 ![]() ![]() |
The 110 came with a few loose parts in the back. There was a set of windscreen wiper blades, grill and light surrounds in silver and a pair of aftermarket fire and ice side steps.
I cleaned and polished the side steps the first weekend we had the truck but I wasn't able to figure out how to mount them. My friend, an engineer at JLR and a Defender expert, fitted them for me. I would have gone for a little less bling, but I already had these so on they went. We also discovered a set of wheel spacers behind the steel wheels. Rather than remove the spacers, we adjusted the locks to get a little tighter turning circle. ![]() Click image to enlarge |
This past weekend:
I fished out a broken captive nut I suspected was sitting at the bottom of the A-pillar. ![]() Click image to enlarge I fixed a problem with the rear door check. I sprayed Dinitrol into the A-pillars and the rear door: ![]() Click image to enlarge I replaced rusty bolts on the rear door and spare wheel carrier with parts from my SS kit. Before: ![]() Click image to enlarge After: ![]() Click image to enlarge and I did this: ![]() Click image to enlarge I noticed the backup light stopped working, but I haven't had a chance to check anything yet. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
Well done with all the jobs you have done so far, a great sense of achievement once they get ticked off, once again, great work
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876 ![]() ![]() ![]() |
Looks like a busy and productive weekend
![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
This past weekend I spent a few hours troubleshooting a fault with the reversing light and rear park assist.
Our Defender has a alphamotiva rear park assist. The park assist is powered by the reverse light. My first instinct was to check for a bad install and loose wire. No luck. It was done professionally. They made up a harness that plugged into the original light socket. I plugged the rear fog lamp into reverse socket - no light... I did some other basic troubleshooting at the back of the car and i checked for power at the fuse. All good. With today's warm weather, the park assist and reverse light started working. That sure sounds like a sticking reverse switch to me. I'll be checking that next. Might not get a change to do any work this weekend or next. Doesn't look like the easiest job either. |
