Home > Puma (Tdci) > Door seals holding water
dashed
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
Has anyone noticed door seals on Puma holding water? Any time I open the front doors after rain there's a fair bit of water runs out of the seals themselves. Part of me says not to worry - it looks to be inside the rubber trim itself, but I can't help but think that holding water for days on end must is some way contribute to corrosion. Has anyone modified the seal to allow water to run out more freely?
You can see the water running out below - it's a couple of days since we had rain and you can see it's still wet in the area:
Post #554707 9th Aug 2016 12:53pm
Vitesse
Hi. Yes my 90xs does this. I just drain them occasionally by opening the doors
I guess once the door seals wear out they won't hold water any more?
Very Happy 2015 90 XS Santorini Black
Post #554712 9th Aug 2016 1:14pm
Zagato
When the door is shut the hollow seals compress, the air is let out by little holes further up the seals. This is where water can enter. If it drains as per your pic it shouldn't,t be a problem.
Post #554713 9th Aug 2016 1:20pm
shaggydog
They all do it and always will Rolling Eyes
Doesn't seem to have any ill effect though as it just fills up a rubber tube.
Just remember to open the doors after you wash it and let it trickle out. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #554715 9th Aug 2016 1:22pm
dashed
THanks - will stop worrying! Thumbs Up
Post #554716 9th Aug 2016 1:27pm
xtr2turbo
United Kingdom 2016 Defender 110 Puma 2.2 USW Corris Grey
I noticed the same. My concern is what happens when it freezes
Post #554727 9th Aug 2016 2:44pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
My 110 Puma was outside 24/7 all year round and in some very cold freezing weather, never had a problem with door seals
Post #554776 9th Aug 2016 6:10pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Mines the same, just glad it drains outside and not inside Shocked
I have one of the dry Defenders Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #554804 9th Aug 2016 8:26pm
shaggydog
Nothing at all, it just expands the rubber a bit and doesn't drain out until it has frozen Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #555018 10th Aug 2016 1:30pm
Happyoldgit
Freezing water trapped inside the seals can expand to such a degree that it can split a Defender in two - seriously Wink Steve.
http://forums.lr4x4.com
Post #555025 10th Aug 2016 1:40pm
