Home > Maintenance & Modifications > Puma oil leaks - worth worrying about?
dashed
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
Just been crawling around under my 64 plate Puma to fit a steering guard and noticed a couple of oil leaks - I know defenders are prone to leaking oil out and water in, but wondering if either is worth a trip to the dealership (still under warranty)?
Steering - only on nearside. Offside looks greased but clean.
Gearbox:
[/URL][/img]
Post #554433 8th Aug 2016 11:12am
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
First picture looks like a leaking swivel seal to me. I think I'd want this done under warranty on a vehicle that's only a couple of years old. Once out of warranty, I probably wouldn't worry too much until it was worse than that.
Can't really see too much of a gearbox leak; just a bit of staining. If drips are forming I would want it sorted. You can't check the gearbox oil level like you used to be able to. You just have to empty it out and refill with the specified quantity.
Post #554437 8th Aug 2016 11:33am
dashed
Cheers Rich - leak on the gearbox is worse than it looks in the pic, not really drips, but definitely wetter than it looks in the pic. Will drop by the dealership at some point and get them to have a look.
Post #554438 8th Aug 2016 11:36am
dorsetsmith
1. swivel oil leak is worth a trip to the dealership (still under warranty)? also get them to check Offside at same time Exclamation
2. gear box or crank shaft oil seal is worth a trip to the dealership (still under warranty)?
both worth a trip to deal ship under warranty Thumbs Up
Post #554442 8th Aug 2016 11:47am
Happyoldgit
As per the others, you want to get them sorted while still under warranty as there is no inbuilt self healing Wink Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #554443 8th Aug 2016 11:49am
williamthedog
The gearbox picture looks like it could be the rear crankshaft seal leaking Neutral
Get it back to the dealer.
Post #554449 8th Aug 2016 12:16pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I had similar gearbox leak fixed under my warranty. Took them two attempts. It turned out to be a gasket on the sump.
Post #554464 8th Aug 2016 12:58pm
dashed
Thanks all - have been in touch with the dealership and will let you know the outcome...
Post #554465 8th Aug 2016 1:03pm
dashed
Sorry, for the delay - just to confirm that the dealership replaced the swivel seal and one of the main gearbox seals under warranty. Thanks all for the advice Thumbs Up
Very good service actually (Stockport Land Rover), they recommended I went through Land Rover assist as the dealership had a long wait for courtesy cars... Defender ended up being picked up by AA recovery truck, I was sent to the dealership by taxi FOC and had a brand new RRS for a week Cool
Post #562640 9th Sep 2016 7:20am
