Home > Puma (Tdci) > Blown Main Fuse HELP Please
KGH
United States 2013 Defender 110 Puma 2.2 HT Keswick Green
Vacation, 14 days, last stop Paris. I used a truck/RV park garage. When I retrieved truck after 4 days, dead battery. No lights left on, Engel fridge definite "off" position.
No jump start attempted. No knowledge of "lock-unlock" or other immobilizer or key proceedures on my part at this time
The attendant helped me push start, drove back to hotel, loaded up wife and kids whilst car running, figured if it ran a while it would recharge battery.
Paris to Stuttgart: Stopped for fuel, as we slowed to a crawl I shut off engine and attempted to restart with key, nothing. Popped clutch and fired up. Fueled up while running and moved on.
Outside Metz, seemed AC was not blowing very cold..50km later 3 Amigos pop up. Turn off AC and they went away...20km later they are back along with limp mode and all guages go flatline. Truck on shoulder of road for 4km and we found an exit from motorway. Truck idles for a bit, then dies. Turn key, nothing.
Flatbed comes, attempts a jump, nothin. Company hauls to German Dealer, who tell me "main fuse" is blown. I believe this means the main fuse link. Do not know specific one, car is 2.5 hours away! They replace, and have started and shut down car, driven around, and all is "güt" as they say here.
So, did the garage in Paris somehow trip immobilizer? Led to no start? Would car run with push start in this condition?
Why limp mode?
Let us hope this is not natural habitat...
I imagine fuse link blew on jump start attempt? Would the car have even run with blown main fuse link? 2013 110 - Keswick Green
1995 ExRAF 110 Utility
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554022 6th Aug 2016 10:24am
KGH
Hello...anyone.... Shocked 2013 110 - Keswick Green
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554066 6th Aug 2016 2:39pm
dorsetsmith
http://www.defender2.net/forum/post79150.html
500 Amp Fuse on the battery + side Part Number: YQF500030
puma tdci 2.4 under driver seat fuse box fuses STC 1757 100 amp blue
stc 1758 60 yellow , stc1759 40 amp green , stc 1760 30 amp Pink
puma tdci 2.2 dash fuse box Lr o75976 yellow 60amp, lr 075974 green 40 amp lr030045 pink 30 amp
Post #554068 6th Aug 2016 2:50pm
dorsetsmith
2.4 TDCi starting drawing
no
if look at wiring drawing main fuse go to start motor and alt the coil will pull in but no 12 volts to main contacts on starter
Post #554070 6th Aug 2016 2:54pm
KGH
This helps, from what I read the glow plugs would continue to be powered with only battery power if main fuse blown.
Brown green and orange continue to have 12VDC.
So could run with push start.
Trying to figure why alternator did not keep charge to battery... 2013 110 - Keswick Green
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554072 6th Aug 2016 3:16pm
dorsetsmith
2.4 puma or 2.2 ?
Post #554074 6th Aug 2016 3:20pm
KGH
2013 2.2
LHD.
I appreciate your help. 2013 110 - Keswick Green
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554075 6th Aug 2016 3:22pm
KGH
ECU prob saw error and somehow alt did not charge battery. Hence cascading failure...AC, then # amigos, then check engine, then no gauge function, then dead. 2013 110 - Keswick Green
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554076 6th Aug 2016 3:23pm
KGH
It seems more and more like the garage guys tried to jump, could not locate battery, and somehow shorted to ground and popped that big ass fuse. 2013 110 - Keswick Green
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554077 6th Aug 2016 3:25pm
dorsetsmith
i have 2012 drawing will up date soon as first drawing posted for 2007 2.4 and not your defender
MY 2012 drawing for your defender
Post #554079 6th Aug 2016 3:39pm
KGH
This helps.
Again, can see where truck MAYBE would run (push start) depending on what else is happening with ECU. 2013 110 - Keswick Green
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554086 6th Aug 2016 4:23pm
K9F
Diesels will run without battery as they are not sparked ignition. Everything else you will lose. Not sure how the ecu figures into the overall scheme of things but basically as long as a diesel engine receives fuel it does not need any electrics to keep it going. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #554110 6th Aug 2016 7:09pm
mk1collector
Alternator might be dead so not charging hence flat battery and the jump start probably popped the fuse. Ray
My build thread
Post #554115 6th Aug 2016 7:31pm
Cupboard
If they have mechanically controlled injection and fuel pumps, however the 2.2 has an electric lift pump and electronically controlled injection so I don't think it would run with no battery?
Post #554240 7th Aug 2016 1:37pm
KGH
Still at dealership.
Heading over to UK tomorrow to picj up a 1995 ExRAF 110 van. Smile
And will wait for dealer diagnostics on the Puma 2013 110 - Keswick Green
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554752 9th Aug 2016 4:38pm
