![]() | Home > Technical > Stainless Steel Performance Exhaust (cut/sleeve or weld) |
Easiest option perhaps would be to cut both, obtain a double ended slip joint and clamp the two together? If you go through life with your head in the sand....all people will see is an ar5e!!
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
Yep, that was my thought so already bought the joint at lunchtime form the motor factors.
Just wanted to make sure there wasn't another better/obvious option (not including sell it on) ![]() Discovery 3 HSE |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I think the exhaust manifold is on opposite sides between puma/td5? 2002 90 Td5 Station Wagon
Maybe...
...but i'm hoping it follows the same route from the middle/cat ish section as i'll join it there somewhere. My downpipe is a really long piece ![]() Discovery 3 HSE |
Update.
I've offered it up and have a problemo. It does come down from the other side like grafty99 says and the dog leg is so extreme it can't be used in reverse. So, I can only use the tailpipe section and a bit more. It would mean it goes from the manifold, straight down the stainless decat I already have, then essentially go straight out the back. No baffles, no cat, no back box. It would mean I have not used the downpipe or middle section (which comes with a baffle section of sorts). What shall I do? Sell it and hope I get more than what I paid? Or just use half of it? Probably can't sell just the downpipe and middle section? TD5 Defender 90 Discovery 3 HSE |
I would sell it complete and then with the profit buy the correct exhaust?
Or maybe see if you can buy the down pipe separately? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Here is the exhaust. I'm still toying with keeping it.
It will fit existing brackets etc. from the decat back (so I could use the 3rd, 4th and 5th section in the pic). Now, mine already has a straight-through decat pipe. If I joined the two together, i would have a straight pipe from the manifold all the way out the back. No baffles, no boxes, no anything. Will this have a detrimental affect on the car (lack of back pressure etc.)? Assuming the noise would also be a tad louder? Cheers ![]() Click image to enlarge TD5 Defender 90 Discovery 3 HSE |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
I was advised by Gary at Alive that no back pressure was the cause of turbo over speed. This was a cause of known failures. As a result I retained the original back box, decat and straight pipe for the rest! 20 K Km's no problems!😀
