![]() | Home > Technical > Start-Up Electrical Issues - 16MY 110XS SW |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
back to LRJ but you mod elect system check all earth from battery to your mod down to chassis and transfer box
do you have away of checking voltage at battery ? Last edited by dorsetsmith on 4th Aug 2016 7:15am. Edited 1 time in total |
| K.M Member Since: 28 Apr 2016 Location: Salisbury Posts: 300
Yea they're coming to collect it this morning
I just hope they don't try and fob me off by saying that the isolator is causing the issues.... |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
You could always temporarily remove the isolator.
| Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696
If I understand correctly, there was a central locking problem before you installed the isolator, and since fitting it you are getting new problems.
If it were mine I would remove the isolator from the circuit and then it cannot be blamed for any of the problems,and LR will have a standard car to sort out. Once they have sorted the problems you can then re-connect the isolator. |
Yeah, thats right.... the issue was before I put in the isolator and got worse after they were 'supposedly' fixing it last time it was in!
Either way I removed the necessary wiring for the isolator and set it back to factory. The whining noise still happened and the other start up issues were intermittent anyway.... luckily the locking mechanism failed whilst the driver was there. Downside... he's only the bodyshop driver and not the mechanic who'll be trying to fix it! |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
quite possible you have two faults, check the wiring that goes through the door (inside the rubber boot) these always break and fail, i should imagine you have a frayed cable.
with the isolator is it rated for the current? sound like it faulty, if you can try a set of jump leads across the terminals (if they can be exposed) 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
I disconnected the isolator before they came to collect the car so its gone back to the factory standard.
When it comes back - assuming they've fixed the door mechanism - I'll double check the isolator before I reactivate the system... where would I be able to check the current capacity? |
| Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310
So when you park up you switch the battery isolator? Doesn't this kill the supply to the 10as alarm system/BBUS?
It's wired around the negative terminal with a 20amp fuse on the OFF so its enough to allow the alarm, immobiliser and the central locking to continue to work but not enough to allow the car to start (blows the fuse, cuts the electrical feed and sounds the alarm etc....)
Right, so she has returned from LR having had a new actuator installed in the door to fix the locking issue.
As soon as I got her back I reinstalled the isolator and on first crank.... the alarm blipped.... With blissful ignorance I put it down to a one-off and thought nothing more of it. After a week of driving around I thought I'd cracked it as it started perfectly each time.... but now its back to normal and the alarm blip is becoming all too common. Time to look at the isolator me thinks! I cannot remember the mm2 of the cable used so I'll have a look late in the week and - if it isn't already - I'll replace with 35mm2 (the same as the standard cable). I've had a quick search and apparently the maximum A draw on crank can be up to 600A with the common start up been around 300A... the isolator is rated at 500A peak for 5 seconds. What would cause a >500A draw? Is there anything else I should be looking in to? FYI - the isolator is wired around the negative, not the positive. |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
I think with the isolator they'll be a momentary disconnect as you turn it, thus causing the alarm to think the power has been cut. Not sure how you get around this....
Cheers Simon |
| All times are GMT |
