![]() | Home > Td5 > hand brake / brake fluid level warning light stays on. |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 989 ![]() ![]() ![]() |
I'd recommend you stop messing about, put it back together and then get it plugged in and scanned. Sounds like a bad ABS sensor or ABS pump fault. Read the codes first then it might help you determine what's up and where to look.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
I don't think I am messing about.
I used my Nanocom and there are No faults recorded. ![]() The ABS has it's own light anyway and a small point I don't have ABS anyway. I found the problem anyway and solved it, but reading your reaction you probably won't like my solution either. ![]() ![]() Click image to enlarge Looking at the wiringdiagram The + is connected along a resistor to pin 9. After a lot off measuring I noticed that the power did not get to pin 9. So with a test wire I solved the problem and the picture shows my permanent fix. RF4 RDS you would peobably go to the stealers and pay €300 or more. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Hey what ever works, man. Glad you got it sorted.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
There's a few odd transistor based drive circuits that board as well. I need to whip the soldering iron over mine when I do an RS order...
