Home > Maintenance & Modifications > Dinitrol over old Dinitrol
excossack
Time for a fresh coat of Dinitrol on the 110. The current stuff is stained with mud, and while some has jet washed off there is still some staining.
Am I OK to go over with new Dinitrol?
The other bits of the chassis need some Jenolite and new Dinitrol. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #553198 2nd Aug 2016 8:17pm
Zagato
If it,s just staining then a light coat of cavity wax first, allow to dry for a couple of hours then underbody wax as usual Thumbs Up
Post #553489 3rd Aug 2016 8:18pm
Rashers
What is the advice for a Dinitrol application if the vehicle has been previously treated with Waxoyl? I've often wondered. Mine was treated before I got it (by the dealer). It still looks pretty good underneath, although the trip across the oil seed rape stubble last week did mark some of the underside. Would it just be better to stick with Waxoyl?
Post #553498 3rd Aug 2016 8:47pm
excossack
Thanks Zag. I have some cavity wax. Smile
I have washed down to remove what mud I can and then I have left to dry with a view to Dinitrol over the top.
Maybe worth a test area of Dinitol over the top ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #553510 3rd Aug 2016 9:15pm
Zagato
Same applies light coating of cavity wax then underbody wax. Make sure the cavity wax has gone off first however.
You are basically spraying on epoxy (glue) which seals and sticks to the surface you are spraying it onto and the underbody wax which is also epoxy based sticks to that although the latter is thicker/waxier, less runny and goes off harder Thumbs Up
Post #553529 3rd Aug 2016 10:11pm
Rashers
Thanks for the advice Thumbs Up
Post #553544 3rd Aug 2016 10:40pm
