![]() | Home > Puma (Tdci) > Help! Yet another 2.4 Puma not starting |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
Anyone? I was meant to be going out tonight
![]() Fuses all look healthy. Don't really know what I'm looking at with the relays, there seems to be a lot of them and no means of identifying them. I disconnected the battery for a bit and reconnected, still same. |
Several things could cause this, my first suspicion would be crankshaft or camshaft position sensors.
Can they be tested?
I could do with a logical diagnostic process. Is that possible without the fancy diagnosis tools? |
do you have any sort of diagnostics tool? It's possible with the cheap ones too.
Have you tried locking it, setting the alarm, and then trying again? I've had issues with the immobiliser before that have been fixed by turning the alarm on and off. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Leaving the battery disconnected completely for a while then reconnected could be worth a try too.
Basic, but easy to eliminate. Last edited by custom90 on 4th Aug 2016 5:23pm. Edited 1 time in total |
I have cheapo diagnostic tool which says no DTCs stored. Have armed and disarmed the alarm too. I did leave battery disconnected for about 10mins to no avail either. A chap on Angry Puma's Facebook group is holefully going to help me out with his Lynx diagnostic tool tomorrow, hopefully that will shed some light on the situation. I'm sort of thinking its alarm/immobiliser related but I don't really know why. |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
I would also say it could be a crank sensor fault. Hopefully his diag tool will have live data and you can see if the ecu is seeing rpm.
It turns out the camshaft position sensor has died.
Does anyone know the Ford equivelant part number for one, so I can try the local Ford dealer tomorrow. |
this may help
![]() camshaft position sensors. ford part number 1358343 Last edited by dorsetsmith on 5th Aug 2016 8:41am. Edited 1 time in total |
Is this one of those sensors it's worth keeping one of in my box of bits as it can disable the vehicle in the middle of nowhere?
I'll let you know the cost shortly and you can decide, but I'd say yes if you are going somewhere remote. Car completely disabled with no warning.
£34.56 +VAT from Ford.
No go with no warning and the part is cheap (half that from people other than Ford), I think I'll be picking one of them up then
