Home > Maintenance & Modifications > Black modulars? |
Take me about 3 hours to get to Kent, just sit tight and I'll come to you! By the time I get there it'll need chiselling off! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Jan 2011 7:42pm |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 |
A tip to stop modulars (or eight spokes) rusting so quickly.
Apart from dings and scratches, it usually starts in the welded join between centre and rim. So when brand new, run a thin bead of silicone sealant (black or clear) round the join, inside and out, which will keep water from penetrating and keep the old ferric oxide coating at bay. MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
27th Jan 2011 2:07pm |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 |
Thanks for that - the tip re rust, not the "chiselling"....!! Simon
'11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
27th Jan 2011 3:50pm |
