![]() | Home > Maintenance & Modifications > Roll Cages |
| wildcamper Member Since: 25 May 2014 Location: Lockerbie Posts: 112
Great now i want a 130
| familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3501
what a beast
Click image to enlarge[/quote] 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
| JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 105
Thanks gents
| BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405
Has anyone fitted an internal roll cage? If I went for one of those in my 90 I would have the padding. A friend said external cages spoil the Defender classic look, which might affect sales, if I needed to sell ever and affect insurance valuing. Outer appeals to me more, but his points ring true somehow Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Didn't know Safety Devices had a fitter in Suffolk, thanks JOE_130
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8478
i think you will struggle with space on an internal cage tbh. i nearly did it on my truck cab for the same reasons - to keep the lines but didnt and wouldnt look back after having a North Offroad et fitted. you are welcome to come and sit in one of mine with cage fitted. older 90s but one with SD front and one with North Cage. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
I think its their HQ... Safety Devices International Ltd Cambridge House Holborn Avenue Mildenhall Suffolk IP28 7AN UK cheers simon |
| Darcy Fairfax Member Since: 06 Oct 2014 Location: London Posts: 721
If you wanted to remove an exterior cage, Im guessing you'll be faced with a lot of holes to fill in. What would be the best way to do this?
JCB Cheers
That would be one way....
Been having a re-think and maybe will get a part internal cage, probably http://www.safetydevices.com/expedition/pr.../276/1796/
Looks like the only internal without front seat brain bashing bars, and which would allow my front seat to be slid back on its Mud rails. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
| tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129
I have safty device 6 points external roll cage. the cage comes with blanking plates. so surely you can take the roll cage off and simply put the blanking plates on. no holes to fill also took me around 30 minutes last time to take the roll cage off. also toghether remove 28 nuts/bolts |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
Hello all,
Need some info before mine arrives... Wondering fi anyone knows, or can measure up quickly, what is the outside dimension of the standard SD cage tube? Ta much if you can help out! Cheers Solved the bowel problem, working on the consonants... |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
