![]() | Home > Maintenance & Modifications > LR Winch Bumper Bolts |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 ![]() ![]() ![]() |
As a rule most folk use the stock mounting bolts. HOWEVER I personally feel and do use High Tensile bolts for Winch bumper and winch mount. High tensiles you will have to paint them to stop them rusting.
What ever you do DO NOT USE STAINLESS |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 625 ![]() ![]() ![]() |
+1 for "What ever you do DO NOT USE STAINLESS"
you will be amazed at how many people change bolts "willy nilly" for stainless, they may look the part and don't rust, but they have virtually no tensile strength whatsoever, fine for small brackets etc. but not for anything load bearing ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Get some 10.9s from a local bolt supplier. Proper hi tensile and surprisingly cheap. Get some paint/grease/anti corrosion something over them and you're golden.
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
In terms of bumper bolts it's shear strength across the section you're after - this might correlate with tensile strength anyway... Solved the bowel problem, working on the consonants...
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8360 ![]() ![]() ![]() |
i use std bolts on mine and they have never proved to be a problem. you will no doubt find there are 6 bolts holding on the winch bumper, normally two more pickup on the JATE ring/chassis mounts.
i run three 90s all with winches and all used hard either for competition work or training or guiding on our Drive Round Days and all these have std bolts with no problems over last 12 or so years. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Normal 8.8 will be OK but I just prefer that little bit of warm feeling knowing it's OTT lol anyways to be honest dare say most winch mounts that failed has been due to Chassis corrosion rather than bolt failure. My old 90 had elongated bumper mounts !!!!
