![]() | Home > Technical > What's this drip? |
| Johnnyboxer Member Since: 21 Aug 2015 Location: Yorkshire Posts: 27
Aircon condensing, more than likely
| nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
[quote="Jonno1968"]I returned to the Landy today to find water dripping from underneath....I got under and it appeared to be coming from the gearbox(??) housing or maybe above it? It was roughly underneath the gearstick, maybe slightly behind. What water is there? It was a hot day, air con had been on and the car had been stood for twenty mins while I was in a shop. There was about a third of a cup full underneath on the Tarmac........should I be worried???[/quot
Mine does the same !there is alot of fluid and the drain is in a stupid place ...just make sure its not oil then it must be the aircon! |
| andrewlandy Member Since: 07 Feb 2016 Location: Graz Posts: 82
Anyone seeing similar issues. I had this exact problem today?
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Probably condensing water coming from the A/C drain pipe. Land Rover in all their wishdom situated the drain above the gearbox... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288
Yes mine does it sometimes after using the aircon.
| Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666
Same here, aircon. D4 does it as well Cheers Simon
I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2789
All vehicles with aircon do it. You just notice it more on a Defender because the higher ground clearance means you see the puddle.
| ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 575
I'm in Spain at the moment and every time I park up I come back to find the puddle, nothing to worry about even though SWMBO sees it as a sign of impending doom ( her 90 doesn't have a/c
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
^^exactly. Me ladies BMW does it too... Solved the bowel problem, working on the consonants... |
| Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95
Definitely the air con, the evoques I work on in plant have a habit of dumping upto a litre sometimes once the Aircon has been on!Alarming the first time you see it!
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
100% aircon! My defender, Range Rover, Audi and transporter does it. 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
| sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250
My Defender doesn't do this...
Wait what's air con? Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
The wife's puma with aircon does it, my td5 without aircon just dumps oil
| All times are GMT |
