![]() | Home > Technical > Brake Systems warning light - help me diagnose.. EBD ? |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 ![]() ![]() ![]() |
Mine did similar and looked like Reservoir was OK but added a few mils of fluid and it was fixed. It would flicker on hills damn sensitive that fluid level sensor
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I have a similar problem, I know it's the handbrake switch. It only works on the last mm of travel, so if I don't physically hold the handbrake down, the light will flicker on/off.
Try holding the handbrake down as your driving along or pull it up a smidge to see if it comes on. The switch is around £10 new so I'm looking for a second hand one...😳 Cheers Simon |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Pretty sure it's not hand brake, but I won't rule it out. I know the switch, I was in that area not so long ago.
![]() I think the 'changes when I accelerate' thing leans towards the level sensor. Just topped it up to a bee's dick under 'max' - coming from a reservoir that was half way between min/max it might be alright in the AM. I'll pull the cap off and see if the alarm lights up according to expectation too. Right now it's defender bed time for me, did a 15hr shift at work so it's time to veg on the couch! Did I read correctly that EBD is an ABS only sensor/feature though? Solved the bowel problem, working on the consonants... |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
Check that the level float in the reservoir cap is completely free to move. Sometimes they benefit from being removed and given a good shake.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Ja, will do...
Pretty convinced it'll be the level sensor. Have confirmed EBD is ABS only also: https://www.landroverworkshop.com/electric...system-abs Solved the bowel problem, working on the consonants... |
It usually stands for Electronic Brakeforce Distribution, so yes.
Sorted.
![]() But a new light: http://www.defender2.net/forum/post552507.html#552507 ![]() ![]() |
