Home > Technical > Td5 air con issues
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Td5 air con issues
Hi all, during the recent weather I have finally made use of my factory air con and it works a treat, only issue is after an hour or so it virtually stops. Motor still spinning but not a lot of blow at all. First guess was blocked pollen filter but I can't seem to find one. Am I right that there isn't one or is there somthing else you wizards can suggest. Cheers in advance ed
Post #551526 27th Jul 2016 8:28am
dorsetsmith
below dash version
http://www.allbrit.de/UNI.cfm?PAGE=761591&SPRACHE=EN#1
show even less
Post #551529 27th Jul 2016 8:48am
RCMike
No idea what could be wrong unfortunately, but it should run continuously cold for many hours (i've had mine running cold for a 6 hour stint at least).
Post #551581 27th Jul 2016 12:22pm
Mo Murphy
TD5 air con doesn't like running full tilt on the 3rd coldness for very long and you get a build up of ice on the evaporator. Try knocking the temp down to 1 or 2 after half an hour and give it a chance.
HTH
50 Shades of Pennine Grey
Post #551664 27th Jul 2016 5:10pm
Millsy94
It ices up even on setting two (takes slightly longer) and setting one is just useless
Post #551677 27th Jul 2016 5:55pm
Mo Murphy
Good old Land Rover 😊
Post #551687 27th Jul 2016 6:28pm
nickhodgson
Does your compressor on the engine cycle on and off? It should. It does sound like your system is "freezing up" - the evaporator is getting frozen and not transferring cold to the air. You also may notice the volume of air has reduced as well.
I would check the thermostat on the evaporator. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #553008 2nd Aug 2016 8:17am
nickhodgson
dorsetsmith wrote:
http://www.allbrit.de/UNI.cfm?PAGE=761097&SPRACHE=EN
This link is to the "in dash" aircon rather than the below dash version. I have not seen a TD5 with the in dash unit. The in dash unit has the vent flaps blocked off and plastic covers fitted where the vents were. 1995 300tdi Defender 90 P/UP
Post #553009 2nd Aug 2016 8:19am
