Home > Puma (Tdci) > Accesory belt desintegrated
Eduardo
Sad
Today my wife call me a little bit upset.
When she return from a meeting outside the city the Defender start to make a clank noise and suddendly she lost the steering and the brakes were quite hard. She stooped and open the bonnet to see what happens fearing the worst.
In summary, the accesory belt dissapear and only some strips were there Sad
Probably one of the bearing or the tensor failed or the belt itself (after 40,000 km I doubt).
So 2 times in less than 2 weeks at the repair shop Evil or Very Mad Eduardo
Post #551498 27th Jul 2016 5:12am
Eduardo
The culprit were found.
The alternator pulley dissapears....
Now the question:
It is possible to replace just the pulley or I need to replace all the alternator Big Cry ?
if it is exists someone have the part N�?
My pocket thanks you advance Eduardo
Post #552290 29th Jul 2016 11:31pm
Alien
Australia
Shocked
Is the thread for the pully nut OK?
I suspect it may be a full replacement job as I'd assume the pully would have been loose while it was driving. Cheers,
Kyle.
Post #552334 30th Jul 2016 9:25am
Eduardo
Probably will be a full replacement work...
Yes the thread looks OK.
But as you said, the pulley is now somewere in the highway
Sad Eduardo
Post #552394 30th Jul 2016 5:44pm
Not too difficult to do yourself I've had the belt off before and was a lot easier than I thought to do.
I wouldn't have thought the alternator would be too difficult either.
However, if somone is sorting it for you that'll make life easier, just hope they aren't charging a fortune.
Thumbs Up
Post #552429 30th Jul 2016 7:08pm
VeeTee
Netherlands
EVR59941
You may find one on a Ford Transit or Toyota Hilux II/III at a breaker, may save some pennies. Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #552437 30th Jul 2016 7:34pm
Eduardo
Thanks Veetee.
Appears that some part of the pulley is still there...
 Eduardo
Post #552624 31st Jul 2016 5:01pm
Eduardo
I take out the alternator today (1 hour work)
In fact, a liitle search of the alternator Bosch PN 0121615003 shown that the shaft will end in a thread
The alternator use the rotor F00M312027
I can see the thread of the rest of the pulley. So probably will be a little bit less expensive...
Now try to found the pulley here in Chile (I Hope)
Cheers! Eduardo
Post #552743 1st Aug 2016 12:04am
Eduardo
Opps. Double posting Eduardo
Post #552744 1st Aug 2016 12:04am
agentmulder
Kuwait
Where did you get the info on the alternator internals? I might be opening mine up one day soon. Solved the bowel problem, working on the consonants...
Post #552745 1st Aug 2016 12:10am
Eduardo
A quick search in Internet with the alternator part N� will do it.
http://woodauto.com/Unit.aspx?Man=BOSCH&Ref=0121615003
And
http://alternators-starters.blogspot.cl/20...ators.html
Regards Eduardo
Post #552818 1st Aug 2016 12:04pm
mk1collector
Wood autos head office is just down the road from me Mr. Green Ray
My build thread
Post #552888 1st Aug 2016 5:32pm
Eduardo
Finally
I found the pulley locally (GBP 45) so tomorrow I will deliver the Alternator for the pulley change.
Quite happy! Eduardo
Post #553239 2nd Aug 2016 9:50pm
Eduardo
Pulley changed.
Alternator installed after 1 1/2 hour trying to align the alternator with the bolt holes (the space is quite limited)
Then put the belt. Quite easy when you know how to do it (thanks to the Aulro forum).
So the Defender is active again after 10 days.
Good things:
1.- I learn how to change the belt in the bush Smile
2.- Cost me only the pulley and the belt Smile
Cheers to all! Eduardo
Post #554161 6th Aug 2016 11:08pm
