Home > Puma (Tdci) > Main internal lighting feed
mse
Anyone know where the main lighting feed is internally.
I need to illuminate a few things on lights on and want to find the best feed to patch into Mike
Post #5489 14th Dec 2008 8:42pm
Eduardo
MSE
Let me check in the workshop manual and the electric library and I will come back (tomorrow, its quite late here!)
Cheers Eduardo
Post #5498 15th Dec 2008 3:47am
Eduardo
Here again
I hope the information is that are you looking for
Item Part Number Description
1 RH (right-hand) rear door switch (if fitted)
2 Front interior lamp
3 Rear interior lamp (Not 90 model)
4 Tail door switch (Not 90 model)
5 LH (left-hand) rear door switch (if fitted)
6 Map reading lamp (SVX (60th anniversary) model only)
7 Drivers door switch
8 Anti-theft system module
9 CJB (central junction box)
10 Passenger door switch
11 Map reading lamps switch (SVX (60 anniversary) model only)
12 Map reading lamp (SVX (60th anniversary) model only)
The CJB is located underside the steering column. Eduardo
Post #5499 15th Dec 2008 4:14am
chalky
That looks very interesting !
What are the Map Reading Lights SVX only ?
Mike !.................Are you doing what i think you are doing ? DEFENDER XS CSW 08 TONGA GREEN
Post #5510 15th Dec 2008 1:06pm
Grockle
Chalky maps lights in front panel of cubby box on SVX. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5512 15th Dec 2008 1:13pm
chalky
Cheers grockle !
I think i may well have to invest in some of those and get them wired in.
More gadgets to play with i suppose ?
I dont suppose there are any SVX owners on here are there ? if so any chance of a picture to illustrate position etc ? DEFENDER XS CSW 08 TONGA GREEN
Post #5513 15th Dec 2008 1:19pm
Eduardo
Not a picture really but can help
Cheers! Eduardo
Post #5515 15th Dec 2008 1:38pm
mse
chalky wrote:
Cheers grockle !
I dont know Whistle what do you think im doing Razz
The lights in the cubby box, switched by a "name escapes me" classic type switch is because the soft top has no interior light...these replace it. Cant say they appeal up close.
Sorry i probably wasnt clear im looking for the interior light (switches and instruments) header...maybe number K109 on the 300/td5 it was in the centre of the dash behind the facia.
On this i cant find it...if i can want to take a direct feed and not piggy back on one of the other switches. Mike
Post #5517 15th Dec 2008 3:56pm
chalky
thanks Ed, that illustrates that nicely,
Mike i kinda get the idea now and understand the whys and where fores of the lighting on the cubby box ! i,m kinda thinking that could be a bad idea as they will no doubt break and be a general pain in the arse positioned there. DEFENDER XS CSW 08 TONGA GREEN
Post #5526 15th Dec 2008 6:20pm
mse
Yes - in short Rolling Eyes Mike
Post #5543 15th Dec 2008 11:43pm
