Home > Maintenance & Modifications > Oil drain valve
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Oil drain valve
Anyone use the difflock drain plug? Is it any good and is there anything similar, or better out there?
Just trying to make oil changes a little more pleasant Thumbs Up
Post #550897 24th Jul 2016 6:04pm
I have one, made by Femoco.
Worth every penny if you do regular services yourself.
Plus points:
No oil can be blown by the wind to all around your drainer... If you do your servicing outside.
No need to buy plug washers every time
No need to fish the plug and plug washer from a tub of used oil
No chance of fudging the sump thread
Make sure you buy the optional hose Thumbs Up
Post #550900 24th Jul 2016 6:45pm
HardCharger
Thinking about getting this plus the units for all the gear boxes as well to make DIY work much simpler and cleaner. Sometimes the shops can get pretty busy for a simple oil and filter change...
Post #551011 25th Jul 2016 2:38am
Mo Murphy
Worth every penny, makes changing the oil so easy.
50 Shades of Pennine Grey
Post #551017 25th Jul 2016 5:59am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
I have one of this :
Femco Standard 90� Straight Drainer with hose 250mm
https://www.drainplug.com/en/packages/stan...21-01.html
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #551030 25th Jul 2016 7:48am
MartinK
+1 - great invention.
Installed mine after the 2015 oil change
Made the 2016 oil changes so much better Thumbs Up Thumbs Up
Worth every penny Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #551083 25th Jul 2016 11:17am
excossack
+2 from me. Makes it easier to drain in then event of overfilling 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #551090 25th Jul 2016 11:45am
Pinky
Thanks for all the replies, looks like the Femco one is added to the shopping list Thumbs Up
Post #551139 25th Jul 2016 4:35pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
I have one too but not yet fitted as my local independent guy forgot to fit it on the last oil change! Ho Hummmmm Cheers Don.
Post #551151 25th Jul 2016 5:06pm
