Home > Off Topic > Pond people...
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Pond people...
We have recently moved and this pond is in the back garden. As you can see, quite overgrown. There are a good few koi carp in there.
What's the best thing for me to do? I want to clear a bit of it as its looking like a jungle. I was just going to pull the crap up, but worried about the fish.
Any recommendations? Think we want to keep it as the toddler loves feeding them.
There is a pump out the back of the shed but is either knackered or at least needs some serious tlc
Cheers in advance...
 TD5 Defender 90
Discovery 3 HSE
Post #550652 23rd Jul 2016 5:51pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
Can't help with the fish but as soon as I read "toddler" my first thought was a secure grill over the top of it ASAP shock:
Post #550658 23rd Jul 2016 6:10pm
Rashers
Never had much experience with Carp. All mine are British Standard Gold Fish and Orfs. We have got vicious with pulling weed / plants out and within reason, the fish seem to cope well. I wouldn't do it all at once. Do a bit at time and let the pond clear before doing a bit more. You will need a good supply of water to replace what you are pulling out. This really needs to be rainwater as chlorinated tap water does not do fish a whole lot of good.
I would second Riverboys concern about a Toddler and a Pond. They really don't mix. If you can't put a solid grill over the top then maybe fence off the pond if you can? The grill will also stop your prize koi's being Scooby snacks for the local herons once you have cleared the pond.
Post #550666 23rd Jul 2016 6:57pm
As mentioned, take a bit out at a time about a quarter I'd say and top up with tap water to compensate for removal.
That won't do any harm in smaller amounts, as mentioned don't replace the lot with tap water though.
What did you want to have in it / do with it? I'm assuming keep the fish you have still?
They can stay put no problem this way.
Post #550672 23rd Jul 2016 8:02pm
Happyoldgit
I used to keep koi and invested quite heavily in both fish and equipment. My advice to you is live with it for a bit and keep an eye on the water quality / clarity. The fish to plant ratio is tricky and you may have found that the current environment is in balance. However if you find the water goes green with algae in the summer then by all means start clearing it bit by bit as per the above.
Efficient filters and aeration help but a cost in both maintenance and running. Steve.
http://forums.lr4x4.com
Post #550675 23rd Jul 2016 8:13pm
Or add oxygenating plants into the water and they do the same job as filters and pumps etc but naturally.
They only need to be pulled out a bit each year so they don't take over.
Native species like Hornwort, are UK native and not invasive and a good oxygenator for the ponds biodiversity and the fish combined.
Water crowfoot and Watercress are another two that are good. (Avoid Elodia, good oxygenator but invasive and non native.)
(Parrots feather again is similar, in fact even worse and has been banned from sale)
The plants in the photo look like a type of rush, perhaps a sweet rush or something like that.
But too invasive for a garden pond unless contained.
Yellow flag Iris would fit in nicely there, but would need containing after a while.
Frogbit is another good species, again native with lots of 1" mini lillipads.
Those are a few ideas but as I said, what you'd like to do with it is up to you.
Post #550711 23rd Jul 2016 11:09pm
huffhuff
Hi all,
Thank you for the replies and concern. There is a big cover that fits over the pond for when she gets a bit more 'adventurous'.
I'll slowly pull out the reeds over a week and top up when I do. They might not be koi in there, maybe just big fat goldfish (orange, white and black)
Ta TD5 Defender 90
Discovery 3 HSE
Post #550870 24th Jul 2016 3:31pm
dorsetsmith
http://www.pondviewkoi.com/j_imported.php or maybe just big fat goldfish (orange, white and black) ?
Post #550875 24th Jul 2016 3:41pm
bcp
2013 Defender 110 Puma 2.2 USW Orkney Grey
I'm a bit biased as I have to pick up the pieces of toddlers vs garden ponds. I'd recommend some decent mesh that a toddler can stand on or make it into a sand pit. Thumbs Up
Post #550943 24th Jul 2016 9:09pm
Stacey007
Hello
We had a pond at the last house and inherited the koi,
Great to watch and feed but a lot of upkeep. It had two huge pump filters sunk into the ground. 3 foam filters in each plus the plastic filers, then a UV lamp which needed a new bulb every 6 months.
Checking the pH of the water, filters cleaned once a month... plus the cost of the koi food.
You may find the filters need s good clean or new ones, then if you have a uv lamp that may need another. Youi can also get all sorts of potions, green away for the algi, We used to take the water sample to our local waterworls. They check it and let us know what we need to do.
As for the kids, depending on size though builders steel grids for putting in concrete work well, don't bend and also help against herons. to be 100% though sell the fish and make it a flower bed...
Post #550951 24th Jul 2016 9:24pm
