![]() | Home > Off Topic > Solar panels and Caravaning |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I have 2 x 100watt panels running through a PWM regulator on 6mm2 cabling charging 2 x 110Ah batteries and the engine battery ( When in storage) on our motorhome. This is enough battery power to run the MoHo for 3 days without the solar panels. The solar panels and the engine (when driving around) keep the batteries topped up. The problem arises on the choices of what to fit as there are plenty of products to choose from. Have a look at the below link which has pages and pages of advice on solar panels, regulators, cabling etc etc.
http://www.motorhomefun.co.uk/forum/forums/solar-power.13/ |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Some basic calculations may help:
To recharge an empty 220 Ah battery you need 220 Ah... A 200 W solar panel delivers 200/12 =16,7 A. So you need the panels delivering full output for 220/16,7=13 hrs. Offcourse you wont drain the battery completely so lets say only 50% then you need 6,5 hrs sunshine. But you also have to account for less then 100% charging efficiency and variable sun conditions... So in fact it is very difficult to do exact calculations, but in general with moderate sunny weather and not to extensive battery usage I would say with this set up you would be be ok. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
T hanks for the replies. Time to start looking at what's available and reading. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to Richard |
| All times are GMT |
