![]() | Home > Td5 > What's this? Van Aaken Smartbox!? |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
It does what it says on the box!!
Unplug it and go for a drive.... see if you can tell the difference ![]() |
you find that it has been wired in red plug of ECU if you unplug my not start
![]() Click image to enlarge uk agents Van Aaken http://www.crdtechnology.com/tag/van-aaken-diesel-smart-box/ |
That's a cheap and cheerful/nasty way of getting more power from the engine. Like a remap in outcome but much more crude and with the potential for more things to go wrong.
It's the same as the old 'Twisted' boxes, you could unplug them and you'll still be able to drive as normal..just slower.
Funkster Member Since: 02 Mar 2016 Location: London Posts: 32 ![]() ![]() |
Thanks for the Guided Tour! |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
I wouldnt trust it.
Probably made by the company of the villain on the left in this picture, on MARS!! [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I'd be more worried if it was designed by the guy on the right!
![]() Click image to enlarge ![]() |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
When you understand how "Tuning Boxes" work, you will soon remove it
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I've got the same box on my TD5. It's been on for 13 years and I haven't had any issues with it.
Sadly, whoever fitted it connected it with those loathsome click lock connectors. I've thought about taking it off and getting a proper remap, but I'd want to replace the damaged wiring loom. Not sure how easy that would be. Cheers Simon |
Is there any direct experience of what goes wrong or what damage these boxes cause..? Cheers Simon |
All they do is ramp up the fuel pressure on CR engines, and inject more fuel.
Not a problem in itself, if it can introduce extra air to cope with the extra fuel. If it can't, the EGTs start to increase, which can result in melted pistons... |
So she's going in for a service and a few minor leak-busting tweaks tomorrow.
What to do with the magic box?! A. Leave it as it is. The performance seems great and so why worry? B. Remove the box. The thought of melting my new toy does not appeal! C. Throw the box in the village pond... If it floats it be witchcraft! |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
Mine had a Van Aaken box on when I bought it. Was on it for near enough 60-70,000 miles I'm lead to believe by previous owner.
Mine came off when I got all the nice bits added with a remap to suit. The early generation boxes all came with the scotch locks. Later ones had a pre-made loom once the plugs where readily available. |
