|  | Home > Puma (Tdci) > pums 2013 clonking on gear change |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971      | Could be the clutch but they usually go wrong in other ways, if it's in neutral with the clutch connected, drive engaged (foot off the pedal) do you get a rattle?
 If the clonk is serious then a possible cause is the intermediate adaptor shaft that connects the gearbox and transfer box. They are a frequent cause of issues. Possible clonks come from that shaft, UJs (but those would have been replaced with the prop shafts), diffs, half shafts and drive flanges. I would assume that they changed the drive flanges with the half shafts but I might be wrong on that one. If the prop shafts or the handbrake aren't bolted on properly you can get some funny noises too. When does it clonk? Is it when you pull away, change gear,...? What do you use the car for, much towing? | ||
|  22nd Jul 2016 12:23pm |
| Rod Member Since: 10 Aug 2015 Location: Sittingbourne Posts: 2      | thanks for the detailed thoughts.
 it clonks as follows. driving, clutch down change gear clutch up clonk, sounds like the center rear area. also does it same set up in reverse. i will check with lr what was done as on warranty work they hand out no paper work, all they said was half shafts and prop. towing wise, not sure i got the lrd at 11k the lady had a pony and small horse box that she said occasionally was towed, didn't think this would stress it too much ? i towed an 8m rib and trailer for years on a ford ranger and no dramas This post has been edited by the site administration team: CAPS OFF | ||
|  22nd Jul 2016 12:44pm |
| defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629      | Could be clutch adjustment is out, Im sure I read on here someone had the same clonk problem due to lock nuts spinning! | ||
|  22nd Jul 2016 1:02pm |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472      | Play in the rear axle A frame ball joint is a prime candidate for creating clunks as are diffs, half shafts, drive members, loose pinion and propshaft fixings. Also check shock and suspension bushes and, as has already been mentioned, you have the possibility of play in the adapter shaft but they are generally either ok ...or you have no drive.
 If that lost doesn't fix it take a look at the clutch switch too. Oh and  Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. | ||
|  22nd Jul 2016 1:09pm |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347      | Or come an see me for therapy....... | ||
|  22nd Jul 2016 3:23pm |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3682      |
 As per Cupboard i would suspect intermediate adaptor shaft mine was clonky and that fixed it DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy | ||
|  22nd Jul 2016 4:43pm |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347      | Is it on every gear change or just under certain circumstances, is it equally clonky each time - can you shed any further light on symptoms? | ||
|  22nd Jul 2016 5:00pm |
| Posting Rules
