Home > Pictures & Video > And we're off...Harvest '16! Post your harvest pics...
Page 2 of 8 <12345678>
JWL
Now that was a damned good explanation Thumbs Up
Post #550302 21st Jul 2016 8:13pm
JWL - It was indeed. Thumbs Up
Cupboard - Thank-you for your post, very knowledgeable and very interesting to read!
Must have taken you a while to type. Thumbs Up
Where I live one farm used to have Deutz, talking ten years ago now though.
That farm has now been moved a bit further away. (Tennant farmers)
Another farm, diversified more or less completely but he does have a near new JD. (No idea on the model)
That has a telehandeler on the front too which you don't see to often unless it's on a Merlo or something like that.
The other farm I can think of has McCormick, they are about the best farm I can think of locally and they are arable.
A bit further away has New Holland.
Combines wise, I can't think of any that actually own one now I'm guessing due to the cost so seem to be using contractors instead.
When they did have one again your talking ten years ago it was a Massey probably around a 20' header.
That was an 'F' reg, do getting on a bit haven't seen that in years now. Laughing
The majority of local farmers near here are tenant farmers and I think largely struggling which is not right.
Although I'm no machinery connoisseur and never used or driven any I've always liked Fendt.
They seem, powerful, smooth and full of kit!
Most seem quite large though so for narrow lanes they might be a bit of a squeeze.
How many farmers actually afford a lot of machinery I do not know especially as many are crippled in many ways.
I know a lot if it you are talking many tens of thousands per machine.
At a guess I'd imagine a Fendt to be £40 -£55k new at a guess?
Either way though as you say if you get a very long lifespan without many breakdowns that can pay off.
Another thing that does concern me, is the fact that many young people do not want to know. (I'm 24).
They've been driven to believe that anything Agri or green fingered or outdoor is for under achievers, or for I quote "old people"
Then there are a few people that are put off by red tape etc but luckily there are a few interested still.
I was pleasantly surprised today seeing a young lady today driving a mid sized tractor and trailer which makes a change!
Another issue I'd imagine is some employment, unless you are a farm owner or tenant farmer yourself.
Would be seasonal employment or income, if you own fine but if you work for a farmer or a farm hand etc things wouldn't be so good.
But those are just my views I'm not an expert on these things but I have lived in the country all my lifetime.
Thumbs Up
Post #550333 21st Jul 2016 11:00pm
Cupboard
A new Fendt for £45k? You'd be lucky.
We bought a small one (412) ex demo for £50k ten years ago. A new 720 (200hp, mid sized) you're looking something like £80-90k. But... the residuals are good, better than a Defender sort of good.
Our combine is about 20 years old now but still does the job. It was a big one back then but is small compared to most that are about these days. Only does 150-200 acres of ours, then about 250-300 acres we do for our neighbours so it's not worked hard, it's well maintained and we've had it from new. Still has what is probably the best name that's ever been given to a bit of kit, it's a Dominator Mega.
Merlo are, I think, the only people that combine a tractor and a telehandler but most tractor makes will fit loaders if you want. Whenever you combine the two you end up with compromises. Tractors with loaders don't have the reach or the lift capacity and you're putting all the forces on the front axle - that's a problem because the front axle is a much weaker axle than the back one (where you might have a 10t or more lift capacity) and the front axle is the one that pivots and has suspension. In contrast, a telehandler front axle is solid and it's the back one that pivots and if it has suspension (which they usually don't), has suspension. If you try and use it as a tractor though, you've got a load of extra guff in the way and much shorter wheels so less ground clearance and traction (and a smaller cab with worse visibility).
Some tractor makers actually supply rear end loaders and you can spin the whole seat round. Loaders tend to go on small, basic tractors so they'll have a transmission with clutches and loading work isn't nice for clutches either. Telehandlers are either hydrostatic or have torque converters.
Post #550356 22nd Jul 2016 8:21am
Captain Speaking
2008 Defender 90 Puma 2.4 CSW Tonga Green
THREAD DRIFT! Rolling with laughter
Interesting though Thumbs Up
Post #550371 22nd Jul 2016 9:27am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Cupboard that is a brilliant explanation above!
Taking this off on a complete tangent what do you think to CAT telehandlers? We have a Merlo and more recently some Bobcat telehandlers but considering CATs next time around.
Post #550397 22nd Jul 2016 11:06am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
On a friends farm a couple of summers ago - just finished a field of rape seed, very dirty crop!
Starting this years harvest tomorrow (North Cotswolds).
Post #550423 22nd Jul 2016 1:01pm
Cupboard
Grain store cleaned and bombed yesterday, harvester going out today. I'm just having lunch and then going back to doing some large scale plumbing down a hole, leaving the people that are actually good at driving tractors to drive the tractors!
Trailer 1 cleaned (that's the only one we usually fit a sheet to, we chance it with the bigger one)
The two harvesters together, haven't had a chance to clean the forager out yet.
A rather dodgy picture of the fire extinguisher having been installed. We share the one between both harvesters on the grounds that we don't have enough people to set fire to both of them at the same time Laughing
Yes, they have been used in the past too.
The things in the background are the maize header for the forager and some cubicle partitions for the cows.
Post #550432 22nd Jul 2016 1:18pm
What is it that normally makes them catch fire? Just blockage abd heat build up?
I've seen Fendt's with front PTO's as well before, but not on many on others I've seen around.
Post #550434 22nd Jul 2016 1:24pm
Fascinating stuff, thanks Cupboard for taking the time to post and explain things so clearly.
Agriculture has clearly changed a lot since the days whan I used to drive an MF 135 and baler to earn a few bob! It didn't even have a cab in those days (did have the newfangled rollover hoop though), and was hot and dirty work!
Post #550436 22nd Jul 2016 1:27pm
JOW240725
Great education from Cupboard, I do think its important people understand modern farming as it often gets a bad press. Modern farm equipment is very big, hi-tech and phenomenally expensive! But I still watch it in awe.
The combines especially work in very dusty conditions and its a combination of dust blocking radiators/ventilation and an abundance of very dry, chaff,straw and dust that makes combines particularly susceptible to catching fire! James
Instagram @suffolk_rovers
Post #550445 22nd Jul 2016 2:04pm
Captain Speaking
Last year's straw and the odd bird's nest! We always cleaned ours out thoroughly straight after harvest to make sure they were thoroughly dry before any ice could form in the winter. Beware pressure-washing a combine when it's minus 5 Laughing
Post #550446 22nd Jul 2016 2:07pm
It's a wonder the air filter doesn't make a perfect birds nest, especially if it's a cylindrical type. Rolling with laughter
Post #550455 22nd Jul 2016 2:24pm
Cupboard
An air filter would make a great nest although I'm pretty sure the inside is the clean side (after all the secondary filter goes in the middle) so the bird would have to nest in the outer section.
Fires? Grot getting tied round spinning things - that caused a minor fire on our grass cutter and on the loader earlier in the week. Bearings going, that's caused us fires before. Flints are a pain round here, if you pick one of them up in the baler and it hits some metal that can set the baler off, particularly if you have a chopping baler as we do. We had one guy set fire to a shed three years ago putting some fresh straw through the straw blower for cow food. Flint on one of the knives, dry straw, 6ft flames out the side of the shed that he didn't notice until someone else drove past and pointed out that he was adding lots more fuel and fanning the fire quite efficiently. Brakes seized on our combine last year - it's a hydrostatic drive that does very little road work so the brakes hardly ever get used. They were used in a field for some reason, one locked on and set fire to the dust around it.
Finally arson is a big issue for farms. It's quite pretty when a straw stack goes up.
Thankfully we haven't had much serious yet but it's so easy for things to go up - that's why we have a fire extinguisher on all our main tractors and the harvester. Some combines have an automatic blow out system that blasts air round them to clear dust. Our forager has a built in compressor for the sole purpose of cleaning it down. The tractors all have compressors for air brakes but we use them to clean stuff too. On board air is really useful Thumbs Up
The forager has got a big rotating screen in front of the radiator to catch any big bits before it can clog the radiator up. That then gets cleaned off by a combined scraper/vacuum arm thing. One of our telehandlers has a reversible fan so when you're doing something mucky and it's clogging up the radiator intake you can push a button and blow it all out backwards.
This time of year is one of the few times I finish before the arable boys, it's nice Very Happy
Until something breaks and I have to go and muck in!
Post #550489 22nd Jul 2016 6:14pm
Probably a good idea to have a fire extinguisher in the Defender too.
Hasn't been long since the silage was done here, looks mostly like Italian Rye to me.
A bit of hay too in places.
Post #550492 22nd Jul 2016 6:24pm
Maris Widgeon
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
We are busy with the green harvest at present, silage making for the dairy cows and beef cattle.
Good weather helps to raise the sugar levels in the grass and make good quality forage which means we can get more production from the silage and feed less expensive concentrate.
Front power take off makes a tractor more efficient and increases it's output whilst also being better on fuel.
This is a crop of red clover which naturally fixes nitrogen and means that we don't need to use any artificial fertiliser and the nitrogen converts into protein for a very palatable, feedstuffs for our livestock.
Once cut with the front and rear mower, it is then raked up two rows at a time then picked up with the forage harvester and quickly taken back to the farm and put into a large clamp to store it for the winter. During the clamping period we remove the air to allow the grass to go through a fermentation process, (that's why we need the sugar) which helps preserve the crop.
Nick
Post #550567 23rd Jul 2016 8:17am
