![]() | Home > Technical > 2003 TD5 Double Cab - Running / Starting problems |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
You have to unplug the red plug and look at the terminals. Ray
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
yes you find the oil if you unplug it
your can use brake cleaner to flush out oil |
| Skelkelly Member Since: 08 May 2016 Location: dubai Posts: 51
Doh!
Will take another look! |
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
As I said before if lots of white smoke probably injector seals and washers not that expensive to have done would be first port of call if no difference when maf unplugged 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
ECU full of oil...
Which is bloody annoying as the dealer promised me they would check this prior to me having it.
Take it back and get them to change the injector loom and clean out all the ecu plug. Ray
They're too far from me to take it back, unlikely they'd do anything anyway...
http://forum.landrovernet.com/showthread.p...s-bradford Shouldn't cost me too much and I'm going to go for a warranty claim, hopefully will get it covered. Just glad it's nothing more serious to be honest! Thanks for all the replies. |
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654
did you disconnect it and look into the contacts? they can look dry on the outside and be literally ringing wet inside with oil.
I'd check RM the seals and the fuel pressure. I'd also plug it in and make sure the crank signal etc is fine too. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
injector loom replacement TD5 red plug clean out
http://www.discovery2.co.uk/Injector_harness.html |
It's in the garage at the mo, had a new loom. Apparently there was a lot of oil in there.
At least it's given me a chance to get the old girl out...
She feels like a jet fighter compared to the Defender! Click image to enlarge |
The red plug will probably need cleaning out about once a week for the next month or two as some oil will still be coming down the main loom. Ray
Had same problem with my 03 about one month clear out oil from main loom
