![]() | Home > In Car Electronics > DAB radios in Defenders |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
DAB round Edinburgh is very good. MrsK's Evoque has it. Chrystal clear.
At home (15 miles WNW of Edinburgh) - I get 100% signal strength on my HiFi DAB - but I do have an 18' aerial in the loft... I believe the transmitter is Fife (Craigkelly) Heading North up the A9 from Perth it gets poor around Drumochter IIRC. In Aviemore, portable DAB radios are not great (nearest DAB transmitter is Black Isle I think), so I have a dipole aerial on the roof of the house and even then only get 40-70% signal strength. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
I have a Blaupunkt Woodstock and it works well. I think it is the same with all these things it depends on the location of the antenna and how it is mounted. Mine has a windscreen aerial.
tmichel Member Since: 23 May 2016 Location: Oberhausen Posts: 7 ![]() ![]() |
I have a Sony MEX-N6001BD in my 2012 TDCI and it works fine with the standard antenna (DAB splitter needed of course).
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 ![]() ![]() |
I've just put a dab radio in the zepplin 300 tdi 90 but I did need to use a specific ariel hxxfords do 1 for about £16 the included lead easily reaches from back to front. If you've not bought 1 yet keep an eye on their website ex demo pioneer cost me £50
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 822 ![]() ![]() ![]() |
I have a pioneer cheapy job without CD from the orange and black shop with a teeny little magmount DAB antenna which sticks nicely to my Brownchurch Rack. Very rarely loose signal entirely even in remote bits of Wales and Devon. The old FM radio on the other hand, well that would only work on one station (which I didn't like) on a day without a Y in it on the ocaission of a blue moon. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
TBH I stream to BT takes away all issues
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
I have one in mine, Kenwood head and roof mounted aerial (Hirschmann expensive but fab)!
Not in Scotland but works well in Derbyshire in all but the deepest valleys, The window stick on aerials are poor as I had one first and was disappointed. |
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 ![]() ![]() ![]() |
I have a pioneer one in my Td5. Drove from Cambridge to Largs and didn't drop signal once. Using a normal wing mounted telescopic antenna pulled up about 1/3 of the way.
Doof Member Since: 26 Mar 2012 Location: Northumberland Posts: 5 ![]() ![]() |
Mine drops signal around home but Seems ok South of Morpeth.
I usually turn it off and use standard tuner. |
