![]() | Home > Puma (Tdci) > Puma 2.4 injector codes label? |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Codes will be on the injectors themselves. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
My web site shows you where the codes are, hope it helps. http://bellautoservices.co.uk/help-faq/bas...ogramming/
Regards Pete |
| vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185
Many thanks Pete.
I have the usual issue where my truck starts off from cold quietly and after 8 to 10 mins it starts to knock under light load (disappears when you gun the throttle) and after half an hour it quietens down - still perceptible but much quieter. Adding 2SO make it less noticeable. It has me thinking whether it needs a pilot learn done perhaps? Anything else I should consider? Cheers Mark |
| All times are GMT |
