![]() | Home > Maintenance & Modifications > Shim style wheel spacers |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
They cannot be much thinner as the material has to be of a certain thickness to take the load and the thickness of the retaining nut has to be below the new mating surface for the road wheel. I don't expect that you will find any thinner unless they are made of steel. NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Curtis-Bay Member Since: 10 Apr 2016 Location: Blockley Posts: 29 ![]() ![]() |
Thanks for your reply NormanD. Yes, I agree that 30 mm seems to be the minimum for bolt on type spacers but I was interested to hear if anyone had used the shim type spacers which simply sandwich between the hub and wheel - they are normally quite thin (5- 10 mm)
Then you have the problem of the wheel nut thread being shortened, unless of course you also change the Wheel Studs for the longer version, somebody will be along to tell you the part number of the stud you would require - 20 off NormanD WE191
