![]() | Home > Maintenance & Modifications > Possible dumb question about Hannibal roof racks |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I can't really see how this happens effectively.
Both Patriot and Hannibal racks have longitudinal rails that run the length. I guess you can get extensions (that's the sort of thing that Patriot would do). The Hannibal racks are welded so it might be more difficult than the bolted Patriot ones. I guess the way they'd do it is by having a short supplemental rack that would sit separately. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
You can't extend the length of either.
You can change the feet configuration for the various versions within chasis lengths though. If you had a 90 pick up say, and changed to an SW, both firms would sell you additional feet to replace the ladders that you would be using to support the back end of the rack over the void of the tub. ![]() |
Sounds about right.
With a Patriot, you could probably go the other way - from a 110 to a 90 ![]() + New Defender 110 First Edition |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
Ok - thanks all. I didn't see how it could work. This may be something I dreamt after a few too many beers on a Friday night, topped off with too much cheese before bed.... Thanks for being polite about it all (at least publicly anyway
![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
No such thing as a stupid question ![]() ![]() |
WhiskyJackR Member Since: 25 Nov 2014 Location: Lizard Posts: 159 ![]() ![]() |
It's Frontrunner that are modular. Any farther South and I'll need to trade the Defender in for a Landing Craft
