Home > Technical > Tracker breadcrumbs
Huttopia
Tracker breadcrumbs
I drive the 110 at between 65 and 70 according to the speedo. The breadcrumb trail on the tracker states I'm driving at 78-85, which is obviously pretty different. Can I safely assume the tracker playback is wrong?
Post #549403 17th Jul 2016 9:52pm
Rashers
I wouldn't like to say for sure. What Tracker do you have fitted??
Every sat nav I have owned with every car I have used them within usually show the car speed to be higher than the sat nav. I would assume the tracker would do the same (if it uses gps to calculate speed like a sat nav).
What's it like at other speeds?
Post #549409 17th Jul 2016 10:09pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I have always believed a stand alone sat nav would give you very accurate MPH readings. In all the cars I have used them in, the car speedo reads a tad higher than the sat nav as again I believed the speedo's were made to read a little higher than actual speed to compensate with slight inaccuracys as it's better to read higher than lower, less tickets that way! Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #549448 18th Jul 2016 6:25am
dorsetsmith
have your tyres all-ways been the size i.e. 205 80 16 and now 235 85 16 0r 7.50 16 as larger tyres will have affect on the calibration of your speeds Question
Post #549459 18th Jul 2016 7:34am
Huttopia
The wheels and tyres are as it left the factory. The tracker is Trackstar. It seems to be consistently high even at 30mph the breadcrumb is saying 34-35. Just noticed I've got a chipped windscreen - that didn't last long! Is the correct part no LR 042759?
Post #549502 18th Jul 2016 10:56am
dorsetsmith
ok as factory Thumbs Up
windscreen
Clear - LR042760
Green tint - LR042725
Post #549571 18th Jul 2016 4:55pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Have you got or can you borrow a car GPS? Then you can get another data point.
My speedo always reads a little higher then my GPS
Post #549601 18th Jul 2016 7:55pm
VeeTee
Netherlands
Every phone nowadays has GPS... Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #549610 18th Jul 2016 8:28pm
Huttopia
I downloaded an app called GPS status and it showed the speedo to be accurate at various speeds. All good.
Post #551098 25th Jul 2016 12:21pm
Motoberg
my Navigon app was saying 73mph on the defender speedo was bob on 70mph !
Post #551103 25th Jul 2016 12:52pm
