![]() | Home > Technical > cheapest way to get memory maps up and running ? |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
thanks again guys.
This will be the cheapest way
http://www.mynewsletterbuilder.com/email/newsletter/1410154891 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Hows that different to the memory map apps you get now for free or £19.99?? Mike |
just need the i phone and that would work a treat
![]() memory map gps or satmap me thinks. |
can't fault the satmap. I find with an iphone 3GS that the GPS is very unreliable. it gets confused between cell towers and actual gps and sometimes is way way out. its not reliable at all. satmap on the other hand is pinpoint accurate at all times and the route recording function is easy to use, easy to save and store the routes. if you get a satmap, get the suction cup mount to, its very reliable. I've been experimenting with an iPad and whilst the screen is fantastic, its a big bit of kit to have in the front if you're bouncing around.
thanks again guys, hints to my better half for my birthday then,
cheers mark |
Here, a good video on the iphone (contains swearing)
