![]() | Home > Maintenance & Modifications > Flatdog Roofrack |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
If someone nicks it then it's easy to replace and that's why it's listed on your insurance as an add on extra
| TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715
Get some security bolts - Devon do a selection of sizes:
https://www.devon4x4.com/security-bolt-set-m10-x-35mm.html |
| taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663
Should of come with black plastic caps. They used to anyway!
| Greadh Member Since: 17 Feb 2016 Location: North West Posts: 97
not on a flat dog, but I added these to cover bright bolts on roof bars:
https://www.amazon.co.uk/Bolt-Nut-Protecti...olt+covers (check size) Also decided it would remove potential snagging of awning on bolt heads |
They definitely used to!
| Tank Member Since: 25 Jul 2014 Location: Fife Posts: 443
Yes they come with covers for all the bolts except the ones which connect the feet to the gutters. Phoned them today and they are looking into it. I know its just sad cosmetics but it would finish it off
Thanks just need to figure out what size I have. They tightened with a 10mm socket I think or maybe a 13mm, need to check then work out what size covers I would need |
I think this is right, but best check....
M4 7mm M5 8mm M6 10mm M8 13mm M10 17mm M12 19mm M16 24mm |
Thank you
