![]() | Home > Puma (Tdci) > Ashcroft's MT82 Output shaft kit "leakage" |
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 ![]() ![]() ![]() |
http://www.ashcroft-transmissions.co.uk/mt...t-kit.html
Well after plenty of reading, I've finally decided to fit the above mentioned kit. I do, however, have a quick question for those in the know or who have fitted one. As this solution allows oil to "leak" from the gearbox to lubricate the splines, I was wondering if you would need to add a little extra oil to the gearbox to compensate for the leakage. From memory the gearbox only takes 2.2ltrs, I already have some BOT328 oil left over from when I changed it at 80,000k's. I don't want to overfill the gearbox, as that can cause other issues, but was interested in your thoughts in regards to if and by how much you might have to top it up. |
In 10k miles mine hasn't leaked enough to be noticeable.
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
I asked Ashcrofts this when mine was fitted and he said it was only a few ml worth of oil so it is negligable, just fill with the normal amount
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8285 ![]() ![]() ![]() |
likewise to ^^ just fill normal amount Cheers
No worries, thanks for that. Just wasn't sure.
Hopefully my LRO International turns up soon, always a bit of a delay in these neck of the woods. |
Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138 ![]() ![]() ![]() |
Hi all! I just ordered my ashcroft mt82 output shaft kit. When replacing the old one unit I think it's better to change the Oring plastic seal no? Has someone the LR ref of this part? Because I think it doesn't come in the ashcroft kit.
Best regards |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Well pleased with my Ashcroft shaft
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 336 ![]() ![]() ![]() |
If you mean item 20 shown below, you do not need it (or item 21) with the Ashcroft kit - the additional part in the Ashcroft kit has seals built in (early ones used a conventional oil seal, the later ones use two o-rings). May be a good idea to replace the gearbox output oil seal (item 4) and the transfer box input oil seal. [URL=] ![]() [/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Hi thanks for the advise. The o-ring I was telling about is the item 4. Do you have the LR ref part of this o-ring pkease? And maybe the LR ref part of the transfer box input oil seal too?
Best regards |
Gearbox output oil seal (item 4): LR0058800
Transfer box input shaft oil seal: IVC100000 |
Thanks for answer! About the transfer box input shaft oil seal... is it not a LR ref part?
Regards |
Yes it is a L/R part, there are many part number prefixes other than LR (RTC, MWC, VHY, FTC and others)
Ok
I understand! With this do you know the ref of the front and rear axle oil seal plastic O-ring? This one where are connected the front and rear propshaft. I don't know this part's name in english. Regards |
Front differential oil seal FTC5258
Rear differential oil seal FTC4851 Transfer box front and rear output shaft oil seal FTC4939 |
