![]() | Home > Maintenance & Modifications > Battery Leads for Dual Battery Installation ? |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Nostromo found this LINK
That article is suggesting a 0.5 volt drop on the bridging cable! However that is for a caravan set up. If Nostromo wants a battery for winching and assuming it is only for the occasional self recovery and not for winch challenge events couple with the fact that he does not want to go down split charge system then I would question the need for two batteries. For self recovery where time is not of the essence. Double line reduces the current draw and halves the effective line speed. Winch for 1 minute, rev engine for 5 minutes to put some current back into battery. Or buy a bigger capacity battery The other alternative is a decent split charge system such as the IBS. Brendan |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
A single, large battery is always the nicest way of doing it Quite how large a battery you can fit in the box I don't know. |
| Mech Member Since: 23 Oct 2013 Location: Oxfordshire Posts: 87
I'd really recommend adding a simple switch. Although I know a lot of guys love em, I agree that relay's are a bit of over engineering. I highly recommend this one.
https://www.bluesea.com/products/9001e/e-S...ery_Switch This allows you to manually connect battery A, battery B, battery A+B (which is the parallel arrangement you identified) or OFF. Just this one simple addition gives you complete control over the system. If you want some added functionality, put the Anderson Connector kit from AutoSparks on the load side of the switch. It may come in handy in the future. |
That seems very small for a Defender battery, most are a lot bigger than that... like 90Ah and 800CCA. It should be a 019 size.
Have you got the engine running? It will work better if you have although you do need to be able to stop the Defender running away!
Yes, one combined store is the best way of doing that, whether that's one battery or two in parallel. The energy density won't vary much, it's whatever fits in more easily. One big one is simpler to wire up but don't get too hung up on it.
There are more than one sort of battery post. Some have a sort of socket with a screw in, they can only really take one. the other has an M10 post that you can put a couple of heavy cables with lugs fitted on to. If you're really pikey or in a muddle you can use a hose clamp, but that's not a good idea
| Nostromo Member Since: 17 Jul 2015 Location: The Mendip Hills Posts: 73
Thanks for the above . . . makes a lot of sense.
I'll post up my analysis of what can be got under the seat in the battery space soon as I've done it . . . and check I quoted those battery ratings correctly . . . I think I did ? . . . but now you've got me wondering ! |
The 8mm stud terminals are quite good and are what we use. However a bit of caution is needed as depending on the height of the batteries which are use the top of the positive stud can get very close to the negative/earth which the battery box lid is.
Be prepared to electrically insulated the underside of the battery box lid or get a piece of rubber etc to cover the top of the positive terminal. Brendan |
That is a very important point, you really don't want it to short out on the lid because it will weld itself to the battery/batteries and you've got yourself a lovely fire underneath your passenger.
Brendan: ooi, can you put them upside down on your batteries? |
Silly boy
Or in this case the angle of the taper on the terminal posts. Plus the height does not change! Brendan |
In my defense the terminals on the little 5AH battery on my desk aren't tapered. That's a lame excuse isn't it |
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605
I just fitted a 110ah Varta Battery 910CC, fits perfectly Old vs New Click image to enlarge |
| Landie Member Since: 21 Jun 2015 Location: WA Posts: 22
Also allows you to check the condition of both batteries. Used this system for years. Can also isolate (dead) battery. Last edited by Landie on 12th Jul 2016 11:59am. Edited 1 time in total |
| Pinky Member Since: 09 Jun 2016 Location: England Posts: 210
I have enjoyed reading this thread and love all the options put forward.
I have, ( installed by the previous owner), twin batteries, one in the normal place and one in the rear tub linked in parallel. The one in the rear is connected to a 3000w inverter for tools of the trade. The only circuitry is an isolator switch under the seat but was told to leave it alone! "Fiddle at your peril". Apparently he had lots of problems switching one off.. I also seem to remember reading somewhere on this site about puma's being very sensitive to voltage changes giving rise to error codes if the correct battery isn't used. My question is, is this true, and would any of the systems and solutions mentioned in this thread cause these error codes as I am thinking of tidying the system up and consolidating it in one place under the seat and was considering adding a switch of some sort. As its running fine at the moment if there is any chance of |
| Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 251
Ive just installed a twin tay from GMB - mount, Im using twin 100 Ah batteries and an IBS split charger.
The IBS is a very smart bit of kit, thinking ahead once I add solar it will allow topping up of the main battery once the Aux is "full". As Brendan mentioned Beat from IBS does know his stuff and has developed some very clever stuff on the charge mangement side. The GMB mount battery tray is a nice piece of engineering, and allows good room for 2 x 100Ah batteries. IBS recommends 25mm2 cable between batteries, but I used 35mm2 and the muti stranded welding cables for easier installation. Im going to repeat the same installation in the 07 Puma we have, as I like it that much. "Rafiki" 2007 110 STW - Rolling rebuild. |
