Home > Maintenance & Modifications > Soundproofing doors
Soundproofing doors
In my 90 I've soundproofed with Dynamat my seatboxes front floor pans only so far.
I've got lots more to do when I've got more of it, good weather and free time.
Probably do doors next, I've had door cards off before so know what gubbins is behind there etc.
Those of you who have done your doors. (May as well do rear door too.)
What difference would you say it made? I'm guessing a slight but noticeable difference like the rest, but added collectively makes a bigger difference the more quieter it is..
I know when I did the seat boxes and floor pans it made a noticeable difference, more solid feeling and sounding. Less vibration and less noise obviously.
Did you just use Extreme on the doors and that's it or the foamy stuff too?
Cost adds up on it all though....
If you've got a different product, although I'll be sticking to Dynamat I'd still be interested to hear what you did have fitted. Thumbs Up
Post #547891 11th Jul 2016 8:04pm
mk1collector
The roof, rear wheel arches and rear floor will make the biggest difference overall as they are the biggest flattest panels but if your stuck on doing the doors it does give them a more reassuring thud when closing them. Ray
My build thread
Post #547893 11th Jul 2016 8:22pm
Stacey007
Hello
I've done both my front doors with 2mm silent coat,
Made a big difference to the sound of the door when you shut it. Previously lets face it it rattles like a tin can especially if your used to a normal car...
After it does thud...much better.
I may put some 6mm foam in there as will if I have any left from the other jobs, but I'm more than happy with it,
I'm still doing the car it bits and bobs when I get the time but its all helping Smile
Post #547894 11th Jul 2016 8:22pm
HossBog
I found doing the roof (on a hardtop) made a huge difference - using 4mm silencoat. Took a lot of the resonance out.
The doors - more of a thud as Stacey007 says, but I didn't notice a massive change.
I've also fitted the dynamat pre-cut system under the bonnet. I'm a bit unsure about that - I think a lot of the sound seems to be bounced back through the bulkhead. 2002MY Defender 90 H/T
Post #547912 11th Jul 2016 9:13pm
Stacey007
^ Interesting about the bonnet as I was thinking about adding that to my list.
May look at other options?
Post #547915 11th Jul 2016 9:20pm
I thought of the bonnet too, but wrote that idea off after hearing others thoughts.
I also thought about doing the dash bulkhead, however, your talking of such a job of taking the whole dash out just to get at it.
Even then, there is various supports etc behind there to fit around. I haven't discounted that idea but at the moment not contemplating doing it being such a big job.
Mk1 - Got my roof to do. Thumbs Up Problem I have with my rear and arches is that the previous owner fitted a CP liner.
I like the CP liner it's great, however, it's bonded with silicone and rivets in places.
So again, a big job to remove just to get at before even fitting the Dynamat.
And before that the seats in the back would need to come out too. Rolling with laughter
Suppose I'll get there in the end. Laughing
I bought one big pack of Dynamat, done all west I mentioned above with it abd have some sheets over.
But I need more before starting doing more, I know you only really need a sheet per panel but as its a one time fit I like to do a job completely and permanently.
Post #547938 11th Jul 2016 10:02pm
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
I silentcoated the entire floor area in the rear of my HT and as an experiment, I just put a six inch square piece on the van top sides and lo and behold, the resonance stopped.
This changed how I approached the doors, bonnet etc and I just put sections of the SC material here and there and it made the world of difference.
On YouTube somewhere is a video of some dude putting a small square of bitumen-based sound deadening material onto the back of a sheet of metal and it does the trick.
The lesson from this is that full coverage is absolutely not required - save yourself a fortune and a lot of hard work and add strategically placed sections of material to achieve the same effect Thumbs Up Phil
Post #547947 11th Jul 2016 10:14pm
Cupboard
Alive have a little demonstration in their waiting room with two bicycle bells. One is normal, the other has a tiny square of Dynamat. You might have guessed that the tiny square stops the bell from ringing and you just get a little "donk" as the clapper hits the bell.
Post #548019 12th Jul 2016 8:38am
languedoc
Scotland 2008 Defender 110 Puma 2.4 CSW Alaska White
I always thought silentcoat, dynamat etc was designed as a resonance killer as opposed to a sound barrier. I have seen lots of cars stripped down before and they have just a square patch in the centre of the panel.
Are we missing a trick here? Wouldn't it be as effective with a strategic resonance killing patch and then fully covered with closed cell foam? Cheaper and exact same results? Or am I missing something?
Post #548025 12th Jul 2016 8:57am
Cupboard
No, you're correct.
A little bit will stop the resonance. I've put a complete but thin layer on in some areas so provide a barrier too.
Post #548031 12th Jul 2016 9:13am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I'd say you were right, Languedoc - back in the day I did my Cortina with small bits of heavy bitumen stuff in the center of doors, boot etc. that Halfords sold (in small squares for exactly that purpose), and it made all the difference.
That's all that was needed to stop the resonance.
Full-coverage in a light-weight foam would still be advantageous for thermal and sound absorption, like in camper vans.
But I'm convinced you don't have to go to the expense (& add to the weight of the vehicle) by full coverage of the dense stuff, although obviously it won't do any harm.
Referring back to the bonnet - I think a soft felt type material to absorb the engine sound would be effective, like most modern cars have, rather than shiny foil stuff which might make the bonnet sound nice when you shut it, but make no difference to the airborne sound other than bounce it back.
Don't know if there is such an aftermarket product?
Post #548037 12th Jul 2016 9:29am
mk1collector
Languedoc, that's exactly right and I've said it on many threads. Fitting pieces of sound deadening in strategic areas will make the most difference but a full covering will have a slightly better overall result and adding closed cell foam maybe mass loaded vinyl over the top will make the best effect at a reasonable price. Ray
My build thread
Post #548038 12th Jul 2016 9:32am
languedoc
It reminds me of the time we had to rebuild an e type series 3 v12 and the previous owner had torched on roofing felt everywhere.
It still makes me cringe
Post #548047 12th Jul 2016 9:55am
Stacey007
I've put 6mm closed cell over the top
I didn't take the seats out as I read that you don't need to cover everywhere also.... But then I have done most areas..
So the closed cell on top.
Using silent coat bulk packs so far I've not thought its that expensive? and it goes a long way. I would not be sure where it needs it best putting pieces here and there so no harm covering more than I may need to?
The soft cell foam I had a 5m roll and still have plenty left that was around £40
Keeps me busy doing this so I'm happy
Post #548079 12th Jul 2016 12:02pm
Cupboard
I haven't put any squishy foam down on the rear floor of mine, just some hard plastic foamboard. The reason being it gets lots of guff chucked in the back and whatever's there needs to be sturdy and fairly stiff.
Post #548105 12th Jul 2016 12:54pm
