Home > Technical > Puma Speed Pulse for Sat Nav?
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Just wondered if anyone knew where the speed pulse is located on the 2007/08 Defender? Looking to fit a new Sat Nav that requires it and want to avoid the £150 for a Can-BUS unit.
Post #6319 15th Jan 2009 11:54am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
hi, looking at the wiring diagram its the red/black wire going in to the instrument panel
this should help you.
Post #7305 15th Feb 2009 3:14pm
bell-auto-services
The speed signal on the puma is not CAN, its a normal analouge 12v PWM signal from the speed sensor on the transfer box, i think if my memory is correct its 5200 pluses per mile.
The CAN part of the speed signal is only used from the instruemnt cluster to the engine ecu.
Regards Pete
Post #7326 16th Feb 2009 12:19am
TJ101
I asked the same question, when the Puma came out,, but never bothered to wire in the speed sensor,,
Unit works fine on mine, without it Whistle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #7329 16th Feb 2009 12:32am
KPNuts
England 2010 Defender 110 Puma 2.4 USW Alpine White
Guess splicing into the red/brown wire would also work for fitting a sensor http://www.devon4x4.com/index.php?page=sho...;Itemid=14 for a brantz trip meter (see my other post http://www.defender2.net/forum/topic5199.html?highlight=).
Can anyone confirm?
Thanks
Keith 2010 110 Utility Station Wagon
1996 110 Station Wagon
Post #54771 24th Jan 2011 11:20am
dgardel
Italy
For my Becker Cascade Pro I taken it from the instrument pannel connector pin13 C1040
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #54862 24th Jan 2011 8:44pm
KPNuts
Thanks for confirming. Sensor ordered.
Where did you cut into the wire? I have the instrument pod out now and there is not much exposed wire between the connector into the pod and the wrapped loom. Is there a more accessible length of this wire somewhere else?
Thanks
Post #55611 29th Jan 2011 3:29pm
dgardel
Italy
Thanks
Keith
But you don't need the interface!
Only an "Y" connection!
I had take off the connector, sold a tiny cable on pin 13.....
Thats all. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #55636 29th Jan 2011 8:18pm
robertgoulet
Hi guys,
I have been reading this thread but things seem to be different in my 08 TD4.. Confused
When taking off the instrument cluster, I have three black/red wires and no brown/red wires. Does anyone know which is the correct one?
Thanks a lot,
Robert
Post #580149 24th Nov 2016 6:25pm
JOW240725
Wow that's thread revival!! Shocked Thumbs Up James
Instagram @suffolk_rovers
Post #580157 24th Nov 2016 7:03pm
Alien
Australia
Maybe Wink
This is the location of the wire used for the speedo pick up when fitting cruise control.
 Cheers,
Kyle.
Post #580256 24th Nov 2016 10:59pm
robertgoulet
Hi Alien,
Thanks! But how can I find out which of the cables enters #13? It is not visible from the back of the connector as they enter it in a big bunch... Is there a way to test this?
Post #580273 24th Nov 2016 11:52pm
Alien
Australia
From memory I removed the cover from the back of the plug.
I did mine @18 months ago but it looks black in your picture.
The wires will not fall out of thier respective positions when removed.
The other method is to probe one of the wires and use a ohm meter to test for continuity to pin 13.
You have a 1 in 3 chance of getting it right first time doing it this way. Cheers,
Kyle.
Post #580274 25th Nov 2016 12:02am
