Home > Technical > 300tdi Injector Leak
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Hi all,
I had to replace the head gasket on my 300tdi and I've now put everything back together. Started OK, but I could feel blasts of air coming from around injector #3. I bought the complete gasket set which included new copper washers for the injectors which I put on. I suspect I have put the new washer on the wrong way round as they are slightly concave on one side.
Can anyone advise me which of the two orientations below is correct?
I put them on as in the first photo, if this is the correct way, is there anything else that can be done to stop the blowing? Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #545895 4th Jul 2016 10:40am
shaggydog
Silly question but are you sure the old washer came out? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #545931 4th Jul 2016 1:24pm
trickster5000
Yep, definitely came out Matt.
Post #545943 4th Jul 2016 2:39pm
dorsetsmith
make shore that washer seat properly over the injector tip also make shore at the injector port hole is clean and the seal washer seat at the bottom of the injector port hole are clean and free from carbon so the copper washer seat metal to metal if you are using old copper washer you will need to anneal them to soften them for reuse
Post #546071 4th Jul 2016 10:06pm
trickster5000
Problem solved! Smile
I borrowed an injector bore cleaning kit off our local garage and used it to clean all the carbon and oil off the bottom of the hole so that the copper seals sit better. Put all the injectors back in and now it runs great - all ticking sounds gone! Thumbs Up Matt.
Post #546233 5th Jul 2016 3:09pm
shaggydog
Was going to be my next suggestion Embarassed
Glad you got it sorted Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #546510 6th Jul 2016 12:49pm
