Home > Technical > Which seal and how can I check?
Grenadier
Bonsoir a tous,
Bit of oil showing under the hub cap and spraying the rear right wheel. Only been a couple of days, as it was clear of oil/spray when I cleaned the Def over the weekend. Not done more than 50kms in that time either, so hopefully not too much oil lost (if it's from the Diff). But I'm not sure whether this is a drive shaft seal failure or hub seal failure? Can anyone tell from the photos and give me an idea of what to check to be sure? Help much appreciated as ever. If anyone wants to offer advice and give Blackwolf a break as he's become my personal mechanic's mate recently, I am sure he'd appreciate it!! Rolling with laughter
Hub cap on:
Cap off:
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #546271 5th Jul 2016 6:22pm
dorsetsmith
17
FTC5268 - ВНУТРЕННИЙ (SEAL-STUB AXLE INNER)
Post #546300 5th Jul 2016 7:38pm
dorsetsmith
Post #546303 5th Jul 2016 7:41pm
Grenadier
Many thanks, great diagram. Easy job? Anything else worth doing at the same time. Perhaps a diff oil change? Monsieur Le Grenadier
Post #546317 5th Jul 2016 8:10pm
Happyoldgit
Errrr ...is not that drive member dust-cap split? Steve.
http://forums.lr4x4.com
Post #546319 5th Jul 2016 8:12pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
what HOG said, was about to post but he beat me to it Thumbs Up 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #546320 5th Jul 2016 8:14pm
Grenadier
Yes. Does that mean anything or is it just an observation and something else that needs to be ordered? No influence on the leaking oil? Monsieur Le Grenadier
Post #546326 5th Jul 2016 8:32pm
jomara
Hi Grenadier the oil/grease you see on the wheel will be coming from the split in the dust cap. It weeps out between the splines of the drive flange and shaft, you can clearly see the oil/grease around the end of the shaft in your last image. At under £1 for a cap it's a cheap and easy fix to try instead of pulling your axle apart Thumbs Up Thumbs Up 2014 110 2.2TDCi XS Station wagon - GONE
Post #546330 5th Jul 2016 8:37pm
Grenadier
Wow. That much egress through the split? Is that normal? Monsieur Le Grenadier
Post #546338 5th Jul 2016 8:45pm
Happyoldgit
^^What he said. Easy to spot and equally easy and cheap to fix. Steve.
Post #546340 5th Jul 2016 8:46pm
