![]() | Home > Off Topic > Which Boost Starter Pack? |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141
A word of warning Shaggydog about micro battery car starters.
First they are really good for most applications charging laptops phones even supplying power to pump up air beds while camping but there is a but and that is even the 18000mAh versions can struggle to turn over a diesel engine with a totally flat battery, if the battery has some power but not enough to crank the engine you may get away with a boost from a micro set up. I have a RoyPow 18000mAh Heavy Duty micro charger that I have used on my wife’s BMW Mini and on a Clio and both have been started, but used on my Defenders with a totally flat battery they only manged to turn the engine over twice, very slowly then they gave up. The trouble is they are designed to turn over engines with low compressions such as petrol engines. On a cold morning with a diesel lump with 22-1 or so compression and a dead flat battery they struggle. If you do purchase one make sure it will start a Land Rover diesel, otherise all you will have is a portable laptop charger. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Judging by the teardown videos on Youtube, work out the cranking amps you need, multiply by 4-5 and then buy one with that rating.
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Thanks Guys
The problem left with the Td5 as a Tdi can be started in about 6ft whereas a td5 is a lot more hassle due to its electrical nature. Very interesting reading though Self confessed mileage hunter |
| DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255
Sealey RS103 for me. Had it years and it's fantastic. Will easily run an Engel for a couple of nights. My Disco 'best bits'
Defender 110 XS CSW 2013 |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Sealey PBI4424S RoadStart® Emergency Power Pack 12/24V 4400 Peak Amps for me both 12 and 24volt starting
