Home > Maintenance & Modifications > Gwyn Lewis Mud Flap extensions
Page 2 of 2 <12
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I'm not fussed about mud up the outside Smile I think it looks better with a bit of mud up the doors, what I do want to do though is stop the mud from a couple of alleyways that I drive up regularly from getting on the crossmember and outriggers. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #545961 4th Jul 2016 4:38pm
Cupboard
In that case all you need is the plastic mud shields and you can leave the front flaps alone.
Post #545962 4th Jul 2016 4:52pm
300TDi CSW Phil
As correct as you are Cupboard I do think it looks better when they are moved so may have to accept less muddy doors Confused 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #545968 4th Jul 2016 5:03pm
Cupboard
Rolling with laughter fair enough.
Get some spray on mud for your Landie?
Post #546103 4th Jul 2016 10:59pm
300TDi CSW Phil
Spray on mud...............I'm sure that was a BMW thing they did when they launched the X5 Embarassed
I think I'll go with the deeper muddier puddle option. Much more fun Laughing 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #546104 4th Jul 2016 11:02pm
Avelingporter
From new the first thing I did after getting dinotrolled was to fit Gwynn Lewis guards front and back to my 90HT.
Fronts easy fit. However I did buy the rubber mudguard relocation kit, but have not fitted it yet. Not sure about the look, but can't fault the quality of the kit.
The rear X member kit was easy enough to fit. Front of rear wheel arch are a little more difficult as you need a second pair of hands to help do up the bolts. You need to trim to fit depending on your model.
Altogether quite easy to fit. They do exactly as they are meant to and come recommended by me.
Post #546131 5th Jul 2016 7:24am
Cupboard
I haven't done the rear crossmember shields, just the ones that go above the mud flap. Do the crossmember shields add much?
Post #546140 5th Jul 2016 7:56am
miker
I'll probably do the fronts on mine first Phil, bored of having muddy water chucked all over me when the window's open! Laughing
Post #546178 5th Jul 2016 11:10am
Page 2 of 2 <12
