Home > Maintenance & Modifications > Rear bumperettes
CarMan
Rear bumperettes
Can anyone please let me know how these fit - thinking about the Terrafirma ones.
I'm thinking most likely the crossmember will not need drilling, but will need rivnuts?
Thanks Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #545390 2nd Jul 2016 6:46pm
Lucifus
Not sure about terrafirma but I use military spec ones. The holes are already present on a factory crossmember and the bold straight on.
Post #545412 2nd Jul 2016 7:33pm
JOW240725
I've got the Terrafirma ones and they just bolt thru the cross member with existing holes.
I like them as they not only given protection to the rear they give 'some' protection to the corner and side. James
Instagram @suffolk_rovers
Post #545414 2nd Jul 2016 7:41pm
nitram17
99.9% of bumperettes are designed to fit existing holes in crosssmember using bolts and nuts to fit threough the crossmember .There is one that requires you to modify the rear corner of the defender but the name escapes me ......i have safari equipment ones you can see the bolts in the picture.
sorry for poor picture ..these are very strong, galvo and powder coated( the powder coating is a little hit and miss )and they will outlive your truck!
little hit and miss )and will outlive your truck!
Post #545417 2nd Jul 2016 7:49pm
nitram17
At the rear the TF bump..are a little to close close to the back of the truck i personally think you are better off with greater stand off which will give better protection..see the SE ones above they stand off much further!Ps its only an opinion!
Post #545419 2nd Jul 2016 7:57pm
JOW240725
I don't disagree they are close so wouldn't take much of a knock and are a nightmare to clean behind, but they look much better than above SE ones Rolling with laughter Also i picked them up 2nd hand off a forum member at a good price so quite happy with them Thumbs Up James
Post #545424 2nd Jul 2016 8:21pm
nitram17
hi jow 2 i didnt mean to dis your bumpers .....you like them and nowt wrong with that...and i have no idea what the OP wants from his bumoerettes......when i was looking for rear corner protectors i wanted the best protection married with the longesrt lasting materials and looks were secondary to me ( although i do like the agricultural look).......ii personally believe that the SE bumperettes are a soilid bit ok kit that will last for years even with patchy rubber coating....aesthetics i leave up to the individual..what make of bumperette does the forum member have on his defender now?
Post #545487 2nd Jul 2016 10:49pm
LR90XS2011
i purchased terrafirma for my 90 but had to send them back as they were poorly made, one hit the body the other was close, on inspection they were not square DEFENDER 90 TDCI XS,
Post #545521 3rd Jul 2016 6:49am
Pickles
I've heard that whilst there are no problems with 110, there may be some issues with some bumperettes fitting 90s?
Pickles.
Post #545544 3rd Jul 2016 8:38am
Offroad-Tec
Germany
Bumperettes
Hello,
I can't remember the problems with the mounting on a 90ty. The fixing points are completely the same, the bumperettes for the 90ty are a little bit shorter and the inclination angel is more steeply. For the mud flaps there must be a little bit space to fit them (photo). Sometimes the rear crossmember is a little bit bended to the front.
Markus
Post #545564 3rd Jul 2016 9:51am
nitram17
Pickles.
I would like to know the issues pickles ?Is it the fact if you have seats in the back you will have to use the same bolt as the seat anchor .if its that i dont see that as much of an issue to be honest you just have to make sure the bolt passes through the anchor..its a little fiddly but if i managed it anyone can!...The only other issue is the mudflaps the SE bumperettes have a cut out to accomodate this i assumed most do.... but maybee not?Off road and in a slow speed dunch with a eurobox or more likely a car door iin a supermarket carpark these bumperettes are going to save you moneyand are well worth it.
Post #545674 3rd Jul 2016 4:58pm
Pickles
nitram,...I don't have them fitted, but I'm sure that I've read on this forum that some bumperettes would not use the original crossmember bolts holes & required some modification on a 90?...Maybe other members can say more?
Pickles.
Post #545821 3rd Jul 2016 11:22pm
Bill1919
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Terrafirma ones are great. Got mine after someone did a lot damage to my vehicle while it was parked. these would have saved it.
Post #711497 8th Jun 2018 9:13pm
Blacksheep
I had the TF ones on my 90, very pleased with them, easy to fit and looks good imo, Shocked but had to remove them when I fitted a spare wheel carrier as they share the same fixing holes in the rear crossmember. Time is precious, waste it wisely...
Defender 90 D200
Post #711544 9th Jun 2018 8:04am
Offroad-Tec
Germany
Hi,
ask your metal shop - the bumperettes can be modificated. I cut them if our customers have mounted a wheel carrier like the mantec one. Surely we cut them b e f o r e the powdercoating Smile
Regards - MArkus
Post #711636 9th Jun 2018 8:43pm
