Home > My Defender > Corris 90
Page 3 of 5 <12345>
mk1collector
Top work Thumbs Up I think your right about the rusty mudflap brackets, the mrs just had all four of hers replaced under warranty on Friday Rolling with laughter Ray
My build thread
Post #545382 2nd Jul 2016 6:35pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
She had a visitor today who just popped by for a spruce up
Post #545729 3rd Jul 2016 8:17pm
ginjez
I managed to get the underside steam cleaned on Sunday in readiness for applying the underbody protective coating. Tonight I removed the rear lights to clean all the cack that hides behind the plastic flaps at the rear of the wheel arches (these flaps are supposed to prevent this). Managed to get the blow gun in there followed by the wash gun. Hopefully all will be dry for the weekend to get her over the pit.
Lost another defendoor today so decided to make use of the filler cap strap and modify the defendoor to end up with this.
Thankfully Brendan always hands these out at the local meets Bow down
Post #546641 6th Jul 2016 8:57pm
I hope you gave that zip tie a 'trim' !!!
Post #546740 7th Jul 2016 7:11am
ginjez
Trust you to spot that Laughing . And yes, I did ask myself why I took photo before going for the snip Shocked
Post #546853 7th Jul 2016 2:56pm
Cake
Great looking truck!
Best of luck with your undersealing - just undertook my own last weekend completing most of it and found it very rewarding and like everyone said you get very dirty!
Just cover yourself in fairy liquid after and it comes off - also make sure you cover the ground around the car too quite a bit out or you get plenty of overspray from the cavity wax as I learnt the hard way
Post #546892 7th Jul 2016 5:41pm
ginjez
Thankfully I'll be in a pit for the task that lies ahead. I've tackled it before on previous Defenders so overalls, filtered mask and spec's at the ready Very Happy . It's the only day of the year I'm not a ginner Laughing
Post #546923 7th Jul 2016 7:59pm
I'll bring the 90 up, it needs some anti corrosion treatment Thumbs Up
Post #546971 7th Jul 2016 10:34pm
ginjez
Thumbs Up anytime Steve
Post #547009 8th Jul 2016 5:54am
ginjez
The underside has now been treated and the corrosion prevention continued tonight.
Any body looking on would think I must be mad - window blocks removed, masking tape to underside of screen gutter and sealant in hand. Windscreen rubber sealed to surround and sealant applied to foam strip under gutter. Thinking about it - I am mad; I shouldn't be having to do this to a nearly new Defender Laughing
Post #548269 12th Jul 2016 9:23pm
Pickles
G'Day from Aussie.
What sort of sealant did you apply to the foam strip?
Pickles.
Post #548315 12th Jul 2016 10:17pm
ginjez
I use an MS polymer pu sealant which is a lot thicker than silicone. You will need to mask up the area as it is very sticky. Use a strong mixture of washing up liquid to smooth off.
Post #548359 13th Jul 2016 6:02am
chrisbridgeave
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
Can you share your polishing tips please
Very shiny Corris grey 90 you have there -and much nicer than mine - how do you do it?
Post #548368 13th Jul 2016 7:40am
Pickles
OK thanks, so it just sits on top of the foam & doesn't sink in like Mr Tolleys Sealer?
Pickles.
Post #548403 13th Jul 2016 9:48am
ginjez
That's correct, it doesn't sink.
@ Chris, I use various products in the cleaning process. When I first got this I washed using steam cleaner with a wash/wax through the snow foam gun, clayed using a Farecla mit followed by Farecla super resin wax and Farecla black top. I top up the shine with Greased Lightning showroom shine Thumbs Up
Post #548425 13th Jul 2016 11:30am
Page 3 of 5 <12345>
