Home > Maintenance & Modifications > Roamerdrive anyone?
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Roamerdrive anyone?
Has anyone fitted or know more about the Roamerdrive? A sixth gear for a Defender!
http://roamerdrive.com/index.html
http://rockymountainspares.co.uk/product/overdrive-defender/ Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #544948 30th Jun 2016 10:25pm
Avelingporter
A friend has one in his 110. Would not be without it. He says one of the best things he has done. Really helps with motorways and longer trips. Even with a caravan it helps.
Post #544994 1st Jul 2016 7:20am
Avelingporter
Sorry , should have said it is a TD5, and has a tune box attached. He did have one problem early on with a collapsed bearing, apparently a bad batch, however the customer service was excellent and my mate was happy with how they dealt with it. Four years later he still really rates it.
Post #544995 1st Jul 2016 7:24am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
I have had the Roamerdrive in my TtD5 for over 2 years now. No issues whatsoever. By far the best mod I have done. it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #545096 1st Jul 2016 4:53pm
MC84
Interesting! Thanks for the feed back. This may be the way to go then. I read you can swap the gearbox out but I would rather keep the original and add to it, like the roamerdrive. Better start saving the pennies!!! Mike
Ford 100e 1959
Post #545120 1st Jul 2016 7:01pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I had the earlier version, Roverdrive on my Series 1, only removed to fit a rear PTO.
Post #545209 1st Jul 2016 11:25pm
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
I had one installed recently on my TD5 and have now put 4000km on it.
At first it made quite a bit of noise which was a bit upsetting but finally after the breaking in period the noise is gone.
It's not really a 6th gear. The best way to look at it is thinking about adding a bigger front ring on a bicycle. When the bigger ring is engaged it changes how many times you have to turn the pedals to get the same speed. It therefore affects all the 5 gears rather than giving you an extra gear.
To be honest I'm not sure how I got along without it. Defenders arent really build for high speed but it sure is nice to be able to keep up with traffic and cover longer distances. It also makes higher speeds more fuel efficient since you are not constantly pushing the engine to keep up high revs. 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #545316 2nd Jul 2016 2:01pm
pannawonica
Australia
Can you not just fit a puma box. I have a 380 gearbox in the mgr and it is a better shifter but there was a conversion kit for the earlier defenders I believe too six speed. Puma box is strong though! Thumbs Up
Post #545321 2nd Jul 2016 2:38pm
